Question about Canon PowerShot A420 Digital Camera
Problem with canon a420 digicam
Camera: Canon Powershot A420 (4.0 MegaPixels) I got a troubleshooter that has to do with my LCD screen & lens, atleast that's what I think. Once I turn on this camera, my LCD screen is BLACK (I can only see pixels, gray/black). Althought this camera comes with the feature that you can push a "DISP" (display) button, to change de view on the LCD screen from "standard" to "detailed" & "None" (the energie saver!). Although my camera has the option to view NOTHING on my LCD screen, I got the problem that the screen stay's black, although my camera is set to "standard" or "detailed" view. Once on "detailed" view. The LCD screen does provide the detailed information like "type of foto", "redeye reduction" etc. But I just don't get anything visual on the LCD screen (atleast not when I want to make a photo). Once I make a foto, while I have no visual on the LCD screen, I make a COMPLETE BLACK foto! Because this camera is 3/4 years old I maybe thought the litium battery was finished (but the camera, doesn't show me this info) So I think maybe my lens is broken?and iam unable to create folderalso
thnx
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Posted on Sep 22, 2009
SOURCE:
Need Canon Powershot A420 instruction manual
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Sep 27, 2011 | Canon PowerShot A420 Digital Camera
The lens of canon a520 camera doesnt retract. My son has hardpressed it and it doesnt zoom in or zoom out.
Hi.
Are you receiving an error on the LCD screen such as "Lens Error" ? If so, this camera is defective and needs to be returned to Canon or an authorized dealer for repair.
If you are not receiving any error messages, does the camera have power (turn on and off) and still not zoom? If this is the case it would also be very unusual without an error message. Either way, you are still looking at a repair for this product.
Typically, a Powershot camera of this age would cost over $100.00 to repair at most facilities. You would be better off purchasing a brand new camera (with more megapixels and features) for around the same price as a repair.
Mar 12, 2011 | Canon PowerShot A520 Digital Camera
Hallo, my canon powershot A420 camera shows horizontal white lines in LCD screen mostly in night shots and the day light shots appear blurred as if more light is entering and the image is not clear.
I am afraid this seems to be a hardware error in the sensor. If the image is purplish in color when blurred it is similar to my and another user's problem. He/she contacted the manufacturer and they said they can fix it for $250. I am not a repair specialist so there may be a simpler cause and solution- good luck.
Dec 03, 2010 | Canon PowerShot A420 Digital Camera
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Jun 24, 2009 | Canon IXUS V2 Digital Camera
Go to the menu system on the camera and navigate to the RESET command and reset the camera. That shouldfix your lens problem.
Jun 19, 2009 | Canon IXUS V2 Digital Camera
Manual
Click Canon Support to download A420 Camera Instruction Manual or click HERE to select different model.
Apr 26, 2009 | Canon PowerShot A420 Digital Camera
Canon PowerShot A420 Digital Camera. When I make a movie how come there is no sound, how do I turn the sound on?
The Canon PowerShot A420 has NO MICROPHONE. That's the reason why you don't have sound on your movies.
The Canon PowerShot A430 does have a microphone! So with that camera you can make movies with sound. You just can't do that with the A420. Sorry!
Dec 04, 2008 | Canon PowerShot A420 Digital Camera
It beeps and lens error on le screen
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 02, 2008 | Canon PowerShot A420 Digital Camera
Elaine, did you accidentally hit the "Disp." button on the back of your camera (upper left button, just below the mode selection wheel). This button turns the LCD screen on or off while taking pictures to save batteries.
Feb 01, 2008 | Canon PowerShot A420 Digital Camera
Restarting the camera
this would be because there is something stuck in the lens..could be the rubber protection stuck not enabling your lens to pop bback into position.i tried gently tapping the lens an gently twisting it to enable movement in my lens
Aug 13, 2006 | Canon PowerShot A420 Digital Camera
Canon PowerShot A420 Digital Camera Logo
316 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
