Depending on the phone you are using, simply go to the menu of the phone. then go to setting, look for Date and Time, select this, then you will is Date settings first, set the date and the format then save by selecting OK, go to the time settings and do the same. It is very easy to do, just go through your phone carefully or better still check your phone manual.
One handset display screen is blank ....remain blank while on the charger ....had the set less than...
(More)
One handset display screen is blank ....remain blank while on the charger ....had the set less than 6mths...uniden dect 6.0
bought the two hand set phone yesterday. set it up and it does not display caller id nor are there...
(More)
bought the two hand set phone yesterday. set it up and it does not display caller id nor are there any numbers in the caller log. I have several other phones in the house with caller ID and the house is equiped with "whole house DSL filter.
How do i check my missed calls? I have a vtech 5.8 ghz and it shows i have 10 missed calls how can i...
(More)
How do i check my missed calls? I have a vtech 5.8 ghz and it shows i have 10 missed calls how can i check the numbers?
I have a panasonic KX-tg6321s phone system. On one of the phones..I can answer a call but when I...
(More)
I have a panasonic KX-tg6321s phone system. On one of the phones..I can answer a call but when I press OFF to end the call the button won't work..If I press it as hard as I can it will shut off..Do I need a new handset?
