PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Toshiba satellite pro 6100 bios reset?
By ryanwins on Dec 14, 2007
I had a bios password on my laptop, and I wanted to remove it. I went into the bios, reset it to factory defaults, saved it, and restarted the laptop. Guess what, now I can't get into the laptop at all, old password doesn't work, and it won't accept a blamk password
Comments:
Dec 14, 2007
- uhh...a bios password generally means it restricts you from getting into the bios, or windows unless you have the correct password.......so no I cannot get into the bios to change the bios password.
Best Solution
posted on Feb 19, 2008
Very Helpful)
BBFatt
Rank: Apprentice
Rating: 100%, 3 votes
The Password can be removed via the printer port
What you need is a password removal tool, It removes the Bios and start-up passwords.
It costs about £5.00. Easy to build but it costs more to put the kit together.
I think you were quite hard on the assistance.
People here are just trying to help. At least appreciate that!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 01, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
higuys.
i have the same problem its useless.changing Ram place ould not reset the bios, and there are o jumpers on the motherboar, otherwise it could be one.i tried killcmos , but its not doingit
the only way i see it is to get what ever you can from the machine lik hard drive, memory, wirels card , modem , and just get it out f your sight.
cheers
Solution #3
posted on Dec 17, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
open case change ram's place or if you have two ram get out of case one of them this reset bios
Solution #4
posted on Dec 04, 2008
Very Helpful)
autremen
Rank: Apprentice
Rating: 100%, 1 votes
to remove the bios password you will need to look for J1 jumper on the motherboard, unlike desktop motherboards with traditional jumpers this jumper is flat on the board are look like two copper pads that do not touch in the center you will need to take a paper clip and short it. Most of the time in most toshiba notebooks it is in the same area as the RAM next to it will say j1
Was this helpful?
Yes
No
Solution #5
posted on Dec 14, 2007
Somewhat Helpful)
MrCk
Rank: Master
Rating: 73%, 11 votes
if u can go to bios then inside it go to the password input tag then click create new password then leave all the password to blank (if there is something in the box in prior clear it ) and save then try it can work only if u can access bios
Comments:
Dec 15, 2007
- hey you connect your hard disk with other computer and take backup if needed then u format the xp containig drive and install new xp with bootable cd so it will default your bios properly otherwise there is not any other chance
Was this helpful?
Yes
No
Solution #6
posted on Dec 15, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This forum has to be the worst for help I have ever used. It seems like nobody either understands what I'm saying or you are all a bunch of idiots!! Obviously none of you have had any experience with bios passwords on laptops, so let me explain. When a laptop is locked with a bios password, it is essentially unusable. The password appears as soon as the laptop is turned on. It appears before you can get into the bios, or b4 you can boot from a cd, so your only option is to find a way to reset the password. It is usually done through a jumper on the motherboard, or by removing the cmos battery, or you may have to replace the bios chip itself, so removing the hard drive, and installing windows on it....is totally pointless, and a complete waste of time. Please refrain from posting information if you do not have a clue about what you are talking about...
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
My acer aspire one will not come on when I turn the power on. The light is on but nothing. What can... (More)
Answer
where is the reset button located on the compaq presario 750us?
Answer
What is the name of the set up file, to install from my driver backup recovery disk, for my zd8000... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
