Question about Kenmore 15073 Stainless Steel Built-in Dishwasher
Rinse Aid The rinse aid does not seem to be operating. Reservoir remains full and dishes have a film left on them
  • vagabond317 May 17, 2008
    I have the same problem. The rinse aid remains full and is not being used. It used to work fine. This problem started after the dishwasher was about 1 1/2 years old.
  • Rick Sauve
    Rick Sauve Oct 11, 2008
    I solved the problem, so far. There is a flow valve where you pour in the Jet Dry that you can adjust. Using a butter knife you can increase the flow going in by turning a plastic screw head to increase the flow. I left it in the largest flow position for a few washes and it started working. I then turned it back to a smaller flow and it is still working.
We have the same problem on a Kenmore model 665.17032. Is is plugged or more likely an electrical problem for release (if that's how it's actuated)? I fine several posts on different sites, but no comments or solutions. Should be a relatively simple issue, surely. Simple mechanism.
Posted on Oct 10, 2008
I have an Electrolux Dishwasher that always starts on low rinse
Hello Friend, this is Z. Thank you for your post!
I see that your Electrolux dishwasher starts cycle on low rinse. This typically indicates your dishwasher has low rinse aid. The RINISING AGENT LOW light, typically located near the Rinse Only Pad, comes on at the end of cleaning cycle when the rinse agent reservoir is low. The light will remain on through 5 successive cycles or until the reservoir is filled. Also, using rinse aid will enhance dryer performance and reduces water sports and filming. Hope this helps!
Jun 04, 2014 | Electrolux Dishwashers
There is a white film on my dishes and in my dishwasher. I've tried using different detergents and rinse aids. Nothing seems to help. Is there a problem with my machine?
try turning the rinse aid dosage down this can be done by turning the small dial located under the rinse aid filler cap, i would start by turning it to number 2.
Regards
Ian
Apr 17, 2011 | Whirlpool Dishwashers
There is residue left on dishes after wshing and a whitish film on the dishwasher door. Looks like mineral deposits. My rinse aid dispenser has stopped working as well. Could this possibly be solved by...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;'';
Apr 03, 2011 | KitchenAid 24 in. KUDS25 Built-in...
White powdery film building up on dishes. Especially noticeable on plastic glasses/utensils. I keep the Jet Dry reservoir filled. This is a new problem on a mature dishwasher. Why is this starting to...
It sounds like you may be using too much rinse aid or have changed from a detergent based tablet to an all-in-one type.
Reduce the amount of rinse aid in your wash by altering the setting on the rinse aid dispenser - usually a dial numbered 1-6. Lower the setting and see if this helps
Jan 25, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Cloudy film left on glassware *rinse aid cup
make sure b4 you start the machine run the water until it is hot then start the machine. let me know if it works by sending me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
White film left on dishes, does not seem to be cleaning thoroughly
could be several things... usually it just needs rinse aid.. all dishwashers spot or leave dishes cloudy without rinse aid.. or your water is just to hard, in that case you will need to soften it with salt, check the owners manual to see how that is done.. also run the dishwasher right after you put the dishes in, if you leave them for a day to wait to fill it up then the dried food gets like cement.
Dec 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I don't know where to put the Rinse Aid
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
May 22, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Motor and pump replaced still not getting dishes clean
Place a cup of vinegar in top rack corner (upright) and run an empty cycle to clean any build up.
Stop using any rinse-aid (jet-dry etc.), if the detergent you're using already has it included. Too much rinse-aid can create a white film on your dishes. A good way to check for rinse-aid build up is to run your fingers on the inside of the cabinet and check for a white powdery residue on your fingers. You can also run the dishwasher for a couple of minutes and check for excess suds in the water when you open it. Excess suds would indicate a rinse-aid build up.
Run the hot water at the tap before starting the cycle and make sure it's at the recommended temperature (120-140°F).
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 15073 Stainless Steel Built-in Dishwasher Logo
145 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
