My Arctica seems to be working, it is cold, making Ice, dispenses water; however, I cannot get the display to stop showing Off. I unplug it because the manual said it may be in Showroom mode and to unplug it and plug it back in. It does not say how to put it in showroom mode so I do not do it again; however, I followed those instructions and after setting the refrig to 37 and the displays shows 0 for freezer and 37 for refrig, once I close the door and reopen the display returns to OFF for both. The buttons on the Freezer display side will not change the temp display for the Freezer, only the Refrig buttons will take it from OFF to show the current Temp and settings. Everytime I hit the refrig control buttons and get a good display, closing the door or pushing the door switch resets them both back to OFF. Help Please.
Comments:
Sep 22, 2009
- Exactly what I thought. Thank you very much. Do you know the exact part number to purchase?
Water is leaking in the front of refrigerator only when the water valve in the supply line is turned...
(More)
Water is leaking in the front of refrigerator only when the water valve in the supply line is turned on. the leak is in the line that goes in the door. is there any way to replace this plastic line
when you press the valve the water comes out in a full stream for about 3 seconds and then goes to a...
(More)
when you press the valve the water comes out in a full stream for about 3 seconds and then goes to a dribble wait a couple of minutes and it does the same thing again. need the part number of the valve and also how do you get the water lines out of the valve? i pull on them but couldn't get them out. looks like they were just pushed in.
