Question about Epson Stylus 2200 InkJet Photo Printer
White bands on my prints
I have been having issues with my epson stylus photo 2200. It has printed beautifully until recently, when i started getting a white band down the left side of the print. I have cleaned the print heads which has, not surprisingly, not fixed the problem--it doesn't look like a dirty print head issue. any suggestions?
  • rob2008 Mar 25, 2008
    I have the same problemb ut only when printing on ultra premium glossy paper. I have done eveything any post has sugested with no luck. If looked at with a loop, I can also see another line of spaced whte dots in a perfect pattern.
  • Anonymous May 09, 2008
    white scratch on the side of picture
Did you try cleaning the decoder strip? It is located behind the print head, looks like the tape inside a cassette tape. If it has ink splatter or a smudge on it carefully wipe it down with a paper towel (damp). It may be easier to remove it, careful not to stretch the little spring on the left side.
Posted on Apr 30, 2008
Stylus 2200, "print test page" in menu, unclickable.
- System Preferences
- Print & Fax
- Select Epson Stylus Photo 2200
- Open Print Queue
- In the top right corner of the Queue window click the Utility button
- Epson Printer Utility will open where you can check the levels and run cleanings and nozzle checks, etc.
May 07, 2009 | Epson Stylus 2200 InkJet Photo Printer
My Epson 2200 prints leaving horz bands about every 1/2 inch. I have not usrd the printer for over a year but did install allnew ink.
Your print head probably has crusted ink on it, as the heads are built into Epsons. If you have tried cleaning, deep cleaning, and then priming (the last 2 aren't available on all Epsons), and it is still banding, you have 2 options:
Disassemble the printer and soak the head in alcohol and hope it works OR get a new printer.
Heads on an Epson are too expensive to bother swapping out.
May 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson 2200 - vertical lines
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
I hope this helps.
Feb 03, 2009 | Epson Stylus 2200 InkJet Photo Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson 2200 printing nightmare
try printing all 7 color individually as a 1st step in diagnostic so you'll know w/c color is actually giving you the problem, no need to do the software this is a hardware problem, it could be one of the ink cartridges,
Aug 28, 2008 | Epson Stylus 2200 InkJet Photo Printer
yes actually there is. the parts its talking about is the inkpad, you can send this over to an epson certifies servicer in your are to have inkpad change and they will reset the counters for it. go this link and look for a servicer near your place
or you can contact epson at 562-276-1300
pls rate as fixya if helpful. thanks!!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
Inkjet photo printing
This may sound idiotic, but print out a nozzle check pattern in your maintenance tab. Good chance you have a clogged printhead. Check out how to do a print head cleaning and what solutions and tools you'll need. Careful if you're using compatible inks or refilled cartridges, or long expired ink.
This one works great for me. Go GENTLY, best not to use Windex or any unauthorized solutions, as they may cause damage to plastic parts.
May 30, 2008 | Epson Stylus 2200 InkJet Photo Printer
is your ink cartridge full and properly alligned, do you have the most recent drivers. best bet to uninstall and reinstall it.
Jul 31, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson 2200 printing problem
More a software problem it imaging try reloading the software[driver] and do it exactly as Epson tell you - disable A/N program for example.
Jul 23, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
