Question about Yamaha RX-V992
Receiver shuts off at times
I have loved this receiver, but the receiver nows shuts off when watching a movie and there are some deep bass tones in the movie. I can then turn on the receiver again, lower the volume and usually are ok. Any idea what could be causing this?
My email address is
Thank you for your assistance
  • 4,234 Answers
There is some leakage of DC voltage getting to the output section. DC voltage will cause the protection circuit to kick in and shut down the amp. This should be a relatively simple repair and cost about $15-$30 in parts plus the local labor rate.
Posted on Mar 18, 2008
My receiver just shut off while watching a movie and won't turn back on. I checked the only fuse i could find. Where to go from here.
Press and hold the "straight" and "Tone control" buttons and press power. This should release the protect lock that the receiver is in. If it shuts back off immediately, then you most likely have a blown amp that will need to be repaired.
Apr 16, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
Those recivers are usually preety good oones with little to no problems. Its just when it gets a certin age it extends its life. You can take it in to a technician to have it serviced, mostly you have cracked solders on the board which will accout for the problems you are having. there might be a few things that need changing but basically your recuver is good it just needs servicing thats all.
Or if you prefer you could get a new one.. BUT YOU CAN JUST HAVE THE CURRENT ONE YOU GOT SERVICED..
a service wil include
re-soldering cracked or loose solders on the board
changing a couple of stuff, maybe capicators or resistors and unlikely an ic.
dusting it
So just take it in to a technician for a service cause its reached it life span ,,
Jan 05, 2008 | Yamaha RX-V795 Receiver
How to adjust bass and treble and surround sound
On the Remote Control
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
The tone cannot be adjusted in the direct
3 Press
to select an item to be set, and use
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Twin Genius speakers model SP-K10 now carrying sound of intermitent machine gun fire on one speaker and deep bass humming on the second speaker. This is new - what can be the cause?
Could be interference from another electrical device or a loose connection. Or you forgot that you were watching Saving Private Ryan.
Turn off the movie, and then try moving them away from anything electrical; TV, monitor, PC mainly. Cordless phones can do it as well.
Jul 25, 2011 | Genius SP-K10 Computer Speakers
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
Feb 25, 2010 | Altec Lansing MX5021 System
No test tone from subwoofer during balance testing Yamaha RX-V430
there's no test tone under normal use for the sub. It only shoud test the three front and two rear. ther' are disc you can use to test all the speakers. ( If you are into Pink Folyd, the movie The Wall has what you need to help balance the speakers
Jan 19, 2010 | Yamaha RX-V430 Receiver
When watching a movies or playing xbox my avr220 powers down when ever there is a boom in the movie or games or tv this just started about 2 months now
Something is getting overloaded.
When this happens:
Is it running hot? Find out why.
Is the volume set extremely high? Turn it down.
Are the speaker settings proper for the types and bass handling capacity of your speakers? Set them appropriately.
Dec 05, 2009 | Harman Kardon AVR 235 Receiver
Hello no deep bass
set crossover setting to 80.
Aug 23, 2009 | Audio Players & Recorders
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
The receiver sound shuts off
There is a problem with the receiver that is allowing DC voltage to get to the output amp section. This is detected and the protection circuit shuts down the receiver. Yamaha uses coupling capacitors between sections to prevent this. If one of these is defective, it would explain your symptom. This should be a relatively simple repair for a repair shop. Expect $10-$25 for parts plus the local labor rate.
Mar 18, 2008 | Yamaha RX-V992
Yamaha RX-V992 Logo
228 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
