Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Mits wd 62327 "NOT WORKING"
HELP..........Have a Mitsubishi 62" DLP model# WD 62327 bought in late 05' early 06'. Has about 18 months of use. In October tried went to turn on the TV and nothing but a green blinking status light which then changes to a yellow lamp light then turns red. Order a new lamp, replaced and no go! Did some research on the net in regards to DLP';s and there potential problems. Here is the kicker "I DIDN'T BUY THE EXTENDED WARRANTY". Had a tech come out and he stated it was the ballast... he order one and replaced it, still nothing. He took my TV to his shop and three days later he tells me it is the light engine. Cost to replace $1,100 and some change.....I'm like yeah right.....I can buy a nice LCD for that price. I then decide to search the net and find a light engine and replace it myself as I am pretty handy......Bought one for $360.00....Came in three days ago and replaced it last night. Guess What? Still nothing!
By pressing the INPUT button and MENU button at the same time I receive green light status code of 3blinks then 4blinks.......which is lamp abnormality! I NEED HELP here on what could really be the potential problem......!
  • more625 Dec 14, 2007
    Where would these be located "K9A20 and K9A21" and "R9A02" right anything could help. I spent $2k on these tv and loved it up until now!
    I really just want to throw it out the front door and let it be!
  • danny1019 Dec 30, 2008
    Mitsubishi WD-62327 will not turn on also timer light is flashing how do i fix it
  • 1,153 Answers
Sounds like you have been catching it with this set! Sorry about the problems, hope this helps!
You need to check a few things like K9A20 and K9A21 these maybe shorted. Also check R9A02 it maybe open. This will cause the problems you are having. Also for more info
Posted on Dec 14, 2007
  • Lashawn Robinson Dec 14, 2007
    Sorry in power supply PWB
  • 87 Answers
I recently repaired a Mitsubishi DLP for a similar symptom. Found C9a37 and C9a38 in the power supply to be defective. They feed the light engine driver. The power supply module is located all the way up front on the left side of the chassis looking from the rear. The module is also shielded so you will have to remove the shields to locate the capacitors. The value of the caps are 3300mf/25v. Good luck
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Where is the lamp located in a 62" mitsubushi tv dlp wd-62327? am trying to install the lamp and can't find it.
Some of their models require taking off the lower front panel. Some are in the back to the lower right corner. There is a cover about 6x6 that is removed usually with two screws and the same for the front except it will be the lower left after the cover is off.
Nov 17, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Have a mitsubishi model wd-62327.lost power now it turns on but no audio or video through any connentions
paid $40 to have a tech look at mine and said its the fmt pcb: 930B931001 & signal pcb : 930B30001
Oct 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Where is the Lamp located in the Mitsubishi 2004 model the number is WD-62327
Turn unit around facing you, either on right rear side or left rear side, generally looks as though it is a vent cover with one to three screws holding cover in place. UNPLUG TV BEFORE YOU WORK ON IT AS ELECTRICITY CAN KILL YOU.
Oct 09, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Picture but no sound
OK, I don't have a 360, but are you sure the audio cable is connected, in the correct jack, and pushed all the way in? Sometimes it looks like the jacks are all the way in, but they are not. Thus, no audio. You could also try using Component 2 if that is an option on the TV. Maybe Component 1 ports are bad. Hope this helps.
Jan 24, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
437 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
