Question about Bose 3·2·1 GS II System
Av3 2 1GS Media center
An oldie but goodie...would like to add external speakers. have stripped wire patio speakers nearby media center..would like to add to system...not familiar with outputs or auxiliary input...Is it possible....
  • avenger3600 Jan 11, 2009
    i would like to connect external non bose speakers to my 321 set is this possible?
  • 126 Answers
Yes, Try Media Receive Ltd - 0845 20 20 118
Posted on Dec 31, 2008
I want to connect my Bose ps28 iii to another reciever. How and what do I need to make this possible. If I run a av left right to the unit will the reciever turn the unit (bose woofer) on.
The media center plug is wired to carry your left/right signal for front and rear along with reference and turn on voltage. Here's a link to the media center cable pinout images. If you have the connector you can pigtail in your high level inputs (speaker out from the amp you want to use to the corresponding pins. However, I can't guarantee this will work. Bose makes these cables proprietary for a reason... to make money. If hillrods like you and I can easily hack their stuff then they wouldn't be able to overcharge for their goodies. Here's the pinout link anyway. Good luck! http://www.google.com/patents/EP1605637A2?cl=en
Mar 01, 2016 | Bose Audio Players & Recorders
Who sang going to the chapel
Wow, now that's an Oldie, And a Goodie!
The Actual Title was: CHAPEL OF LOVE.
Knocked The Beatles out of the top spot on the Billboard, almost 50 years earlier from the date of your question, June 1964.
Recorded by "The Dixie Cups"
https://en.m.wikipedia.org/wiki/Chapel_of_Love
...and the lyrics are here:
Chapel of Love Lyrics
And...
Feb 25, 2014 | Miscellaneous
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Windows media player won't play any audio selections , says can't find files
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
Xvid for windows vista
I've spent a lot of time this weekend finally setting up Windows Vista Media Center, and I suddenly realised that Vista Media Center won't play Xvid and Avi files even if Windows Media Player will. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the Media Control Plugin For Windows Vista Media Center.
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)). FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
The Media Control Plugin for Windows Vista MCE also adds the following additional features:
  • Switching embedded audio and subtitles streams while playing a video: works with AVI, OGM, MKV
  • Switching between external subtitle files (.SRT, .SUB)
  • Switching between FFDShow presets (audio & video)
  • Setting and loading bookmarks inside a video with visualization of the pictures of the saved bookmarks
  • Real fastforward (and rewind) exactly like in the TV module (with 3 different speeds)
  • Switching and setting post-processing filters in FFDShow (video filters only)
  • Separate application to assign keyboard/remote control shortcuts to the commands and the MCML pages of the plugin.
  • Full remote control support (6 buttons are mapped by default, but this can be changed)
  • Default mapping (works in full screen while watching a video, except the blue button that is always caught) :
    • Fast forward / rewind buttons
    • Blue button : loads the startup page of the plugin
    • Red button : switches audio stream
    • Green button : switches subtitle stream
    • Yellow button : switches subtitle file
May 06, 2011 | Dell Computers & Internet
CAn I hook up externa speakers for the jute box Rock Ola 480
That depends if you have skp out or a head phone jack .If so the RCA out jack would
have to go to the input of your amp.
or the head phone jack could directley
drive a small set speakers , the 1/4 or 1/8
head phone jack plug wire from a old
pair of head phones would be strip and
wired to small external spk , or driectly
to the auido amp But keep the volume
on the Rock Ola very low if you
chose the latter ,as not to over drive
your amp.
for spicifics
Jul 03, 2009 | Audio Players & Recorders
Bose PS 3-2-1 II speaker exspansion
Unfortunately this is impossible on the 321 series II systems. There also is no audio output on the media center to send to another amp either. As you may know, the 2 speakers are actually 4 speakers. Each small speaker array has 2 drivers. The 2 on the outside will project rear-channel audio to the sides, so placement of these speakers is important. Honestly, adding speakers would not make this sound very good. If the sound isn't too great as is, make sure you're using digital audio cables (optical or coax) from any external sources like a cable box or Blu-ray player. (if you don't see a Dolby Digital 5.1, DTS 5.1 or PCM 2.0 read-out on front of the media center, you'll know it's not digital. DVDs the exception)
Jun 18, 2009 | Bose 3·2·1 II System
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
Want to test to see if bose lifestyle 18 works.
Hi sorry but what do you mean that you have lifestyle 18 system? The lifestyle 18 system consist of the media center/DVD player, the bass module, the satellite speakers and the RF remote control (aside from tons of cables)
If you have the media center/DVD only, then you require the power adaptor. you can test if the media center is functioning if the LCD display is working. you can also connect an external powered speaker or an amplifier fro mteh AUX out behind the media center.
Do note that doing so will only give you limited control of the system since you require the whole lot to make everything work properly.
Glad to be of service.
Jan 27, 2009 | Bose Lifestyle 18 System
Bose 3·2·1 GS II System Logo
896 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
