Question about Pioneer AVH-P5700DVD Car DVD Player
Screen wont move
I have had the avh-p5700 for almost 8 months now for the past week the screen was closed now it wont move when i press the button , it beeps and sounds like its trying to move but still no movement , any suggestions im using going back to the retailer where i purchased it as a last resort because they said it would have to be mailed to pioneer for service which could take up to 3 weeks
  • Anonymous Feb 03, 2009
    its always worked opening and closed,except today out of nowhere it just closed on its own and it makes the beep when i press the open/close button but does nothing...any help on what it can be?
    Scholar:
  • 67 Answers
Hi I also am a technician in Michigan who has serviced many Pioneer AVH Models. LCD Open Close Chassis is most Likely Bent. Usually the Best Fix is to replace LCD Chassis assy. My charges on this Repair is Usually $160 including return shipping. Unless Gears are Just damaged then it would be less. The AVH-P5700 have Upgaded Gears compared to the older AVH-P6500 that are all Metal and If they are Damaged Chassis is usually also bent up. Any Questions Kstahl65@att.net
Posted on Jan 05, 2008
    Problem Solver:
  • 4 Answers
There is a guy on ebay who does that repair service on the Pioneer AVH models. I thinks its $100 and change for the service plus shipping costs. Not a bad deal, beats going Pioneer! His service is also same day. http://cgi.ebay.com/AVH-P7500dvd-AVH-P6500dvd-MORE-repair-service_W0QQitemZ180196772416QQihZ008QQcategoryZ32825QQcmdZViewItem
Posted on Dec 22, 2007
Pioneer avh p5750 screen wont close
look for a small reset button behind face. or unplug the unit, wait 30 seconds and reconnect.
a simple reset should do the trick.
Nov 22, 2012 | Pioneer AVH-P6500DVD Car DVD Player
How do you set the alarm clock for a model:38229-1 clock
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
Aug 22, 2011 | Audio Players & Recorders
I have a AVH-P5700DVD and the screen is off on calibration, if I hit the play button, it actually hits the button to the right. Does this stereo have a way to calibrate it or is it possible that it is...
In order to calibrate the AVH-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
Aug 11, 2010 | Pioneer AVH-P5700DVD Car DVD Player
AVH-P5700DVD Car DVD Player: how to re-calibrate the touch screen for a Pioneer...
In order to calibrate the AHV-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
May 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Can not change time!!
TO SET ALARM:
Good luck and please rate 4 thumbs up for the free answer
Apr 22, 2010 | SkyScan 86709 Atomic Wall Clock
I can't reset the time on my clock
TO SET ALARM:
Good Luck aqnd please rate 4 thumbs up for the free answer
Avh p6600 screen wont come out ,comes out like once a month
if green wire is connected to ebrake then pull the ebrake and it will open, if you want it to open while driving you have to wire green to ground.
Oct 22, 2008 | Pioneer AVH-P6600DVD Car DVD Player
Pioneer avh-p6500
press the reset buton to make the screen problem rectify itself
you need a hideaway unit for adding subs
Aug 23, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Avhp-6600
i have the same problem with my unit. there is a way to reset the screen so it starts to come out again as i have done it 3 times before. i forgot the exact method but it involves the "rear" "band" and "reset" buttons. i found this out through calling pioneer canada tech support and i will call them again on monday when they open.
May 15, 2008 | Pioneer AVH-P6600DVD Car DVD Player
Touch screen not responding correctly
have the avh 5700 should be close to the same unit. try holding the two center buttons on deck [boost and arrow button] i think then without releasing them push the reset button with a pen ,the screen will close then reopen now let go of buttons should be in the right menu on the first item dont trace the extreme edge come in a little then the second item on the menu screen is the touch section just touch the little plus button on screen if still off try tracing first screen little further from edge. this should fix problem
Mar 13, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH-P5700DVD Car DVD Player Logo
896 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
