Question about Olympus WS-100 Digital Voice Recorder
Files do not appear on PC
When I plug in the recorder the folder for the recorder opens, but I am denied access to playing them. Is this scenario a codec problem? I thought it may be a problem with my computer and tried it on another computer. Now the files are not appearing at all. The folder opens but it is empty. The files are not recognized by the computer. The files are still on the recorder and plays, but I have no way of transferring them to my computer.
This is the only place I found online for troubleshooting for the Olympus recorder. Doesn't Olympus even have it's own support network???
  • 44 Answers
The computer not support the file format. use DSS player to convert the file format to wav and then to any other audio format. or use the SONY LAS VEGAS 7.0 OR 8.0 to convert it into required format.
best of luck.
Posted on Feb 10, 2008
C:\ is not accessible access is denied
Try right clicking on the folder, then go to properties, then the security tab. You may have to change or edit some of the permissions in there.
Feb 03, 2014 | HEWLETT-PACKARD HP Pavilion dv4-2165dx...
Removing 'Access denied' error from folders and files using Unlocker Assistant
Copying files from one destination to another is a practice that goes on a lot among PC users. Sometimes huge sums of data are moved from one hard disk to another. Now there is this error that happens a lot where, when the mouse icon is placed on a folder, you see 'folder is empty' even though you know that the folder you copied is not empty. When you try to open it, you are told that access denied. Most of the files too may not be accessible and will also give access denied error. This is a frustration that can make one think that his/her files are lost. Well, there are ways out and even though it might take time, it's worth it. The following, is a solution to this problem using the software, Unlocker Assistant;
1. First, you would have to obtain the software on the internet. It's free and you can easily search and download it in a few seconds.
2. Install it by following the instructions and you are ready to go. Now, if you are using Super Copier, Unlocker Assistant may fail to start so if you do, then uninstall the Super Copier for the time you would use the Unlocker Assistant. You can install it back when done.
3. Now create a folder on another drive with enough space, different from the one with file and folder errors.
4. Now right-click a folder (one with access denied and empty folder error) and select 'Unlocker'. Among the list of actions, you select move and select the folder you created as destination. If the moving goes through, a success message will show and state that object was moved which means everything in that folder is fully unlocked and is accessible.
5. If the moving does not go through, it will ask you if you would like to move the object the next time you restart. If so, select no. Now refresh and check the folder again and you will see that this time, it is not empty and it is accessible. Now open the folder and repeat the same thing with all other sub-folders. Now this might take time depending on the number of folders you have so you might want to ignore folders that you do not need.
6. Now after you have unlocked the folders, you come to the files in the folders. Select all the files in the folder and right-click and select move. Create the same folder name at the destination for easy recognition. All the files will moved. If the file sizes are very big, you might want to take a little at a time but if they are all small, then you may select all.
7. Now every file that is moved by Unlocker is now accessible. Pictures, movies and all other file types can now be accessed. After everything, you may then move the files back to the disk that had the file and folder errors.
That is all. You are done. Hope this was helpful.
on Mar 04, 2010 | Computers & Internet
Files and directory listings on a Web Server
Without knowing what software you are using its hard to give specifics but it sounds like you need to change the permissions on the folder. You may have the "read" attribute set but not the "list" attribute, you can open the file if you know its name but not list the contents of the directory. Unfortunatley these permissions must be set from the server side.
May 10, 2010 | Computers & Internet
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
Access denied to documents and settings folder
The account that you are accessing; is it an Admin account, and now from the very account you are trying to access that account is a limited one, Is that so?
If that is the scenario, then there are ways through which you can get an admin access, but IF those files aren't there or are corrupted, then that is something else.
I'm waiting for your response...
Also get the properties of that account folder and tell me that folder size, to have an idea that is there something in it.
Regards, WAQAR.
Dec 12, 2009 | Microsoft Windows XP Professional
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
File is not accessible. Access is denied message
Sorry for the delayed responce. Ok first thing is first. The "files/folder is not accessible" occurs because the program cannot find the files in the place where they should be. for example if you put your socks in a draw and your wife moved it, when you return you wont have axcess to them right :) will basically its the same thing here. What you will need to do is find the default directory of itunes it should be in the Options or tools ir settings menu (I dont use itunes so i am not sure just play around in the program until you find it) once you do you need to search you computer for where the PC Backup put your files ..
click start then search and type the name or piece of the name of a song you know should be there. Once you find it browse to the directory of where the song is located. Click start then my computer then local disk to get to your harddrive. Go to the folder that has the songs and copy them. then paste them into the directory where itunes is looking for them.
Jul 06, 2008 | StompSoft BackUp My PC 2005 (05004) for PC
Olympus WS-100 Digital Voice Recorder Logo
137 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
