Question about Eagle SeaChamp 1000c Recording Sonar Mapping GPS Receiver
Ademco Alarm System - Zone works opposite? Triggers on (door closed)/ Stay Off (door opened)?
My zone one (front door). Alarm goes off when the system is armed and door is closed (sometimes in the middle of the night, when door is locked and closed tight). The opposite is also true. If I arm the system and the open the door (to get the alarm to sound), it is silent. Is this a polarity thing? What happened to my system?
I dont think it polarity not unless alarms in the usa are different from nz aus uk sounds like you have a faulty something. try open and closing the front door and look at the keypad to see if the zone activates as it should. there can only realy be 3 things. device, cable or panel fault. you can easly test the system by swaping the zones in the panel ie zone 1 to 2 and 2 to 1 providing that they have similar zone charectorists ie "entry exit" if the fault moves to the other zone you know its a device fault.(inspecting the cable for damage is probably the easy thing to do) if its a reed switch you could look at the position of the magnet it may be making borderline contact and a slight movement of the door could be tripping the zone. if the fault doesnt move its a panel fault. before you jump in though make sure that if you dont comprimise your protection or insurance by trying DIY security. good luck (if you have no joy post more details)
Posted on Dec 14, 2008
New apartment with A honeywell ademco 4110xm. I connected power and got master code. I get CHECK 05 and ALARM 06. Typing the code and OFF disables the ALARM 06 error, but Check 05 remains. Any help?
It is telling you that a zone is not working properly or is open. Ex. door not shut, window not shut. Something moving in front of a motion sensor. Fin out what zone 5 is and that is your problem for arming. Could be a battery if this is a wireless system.
Jan 18, 2016 | Honeywell Home Security
Why does a 5816 door sensor in my Lynx 5200 system send a fault message even when system is disarmed?
Jon, I am not 100% sure what you are asking about. However, is the keypad shows 'Ready to Arm' when the door is closed and then shows the front door in fault when you open it, then that is how it is supposed to work. When the system sees a door open or movement, then it shows on the zone in fault on the leypad. If you were to try and set the alarm with the door open, the system can tell you which zone needs to be corrected before you can set it. Usually it is as simple as closing a door or window. When the door is closed and it says that it is ready to arm, you are good to set and leave. Opening the door with the alarm off or on will report on the keypad.
Dec 29, 2014 | Honeywell 5816WMWH, Wireless Door/Window...
False alarm
If it's showing alarm and the number 06, this means the panel believes zone 6 went into alarm. What's on zone 6, motion, door, panic button?
Nov 27, 2013 | Honeywell V15P-WLS - Ademco Vista15P...
Vista-20p/ps series. when set for ARMED AWAY and after the delay period, the system become ARMED STAY. why is it?
If you arm and do not open the door programed as an entry/exit the system will still think you are inside. So it will only arm your perimeter and not the interior motions. Be prepared for your motions, if any, to set off your alarm if you arm, open door then close it and stay inside.
Sep 18, 2013 | Honeywell Ademco Vista 20p And 6160 Keypad...
How do you disable a zone on the alarm system
I have an Ademco Vista 15 and have been trying to reset the alarm code. The owner did not know the pass code. Cant seem to get anything to work. Anyone know what works????
Jul 30, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
How do you delete a zone from the alarm system?
Welcome to fixya
I have a solution for this
Content
These alarm systems are best used by setting up each zone first, if you attempt to delete a zone, you risk deleting important configuration information.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
ADEMCO alarm system indicates A/C not ready. What does it mean, how to fix it?
Turn the alarm off two times. If it still indicates A/C not ready, press the * key and it will tell you what zone is open or what zone has a low battery.
Nov 22, 2009 | Honeywell 5804 Ademco Wireless Security...
Master code setting couldn't do it (alarm system ADEMCO VISTA-10)
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jun 14, 2009 | Eagle SeaChamp 1000c Recording Sonar...
GPS Logo
501 people viewed this question
Top Eagle GPS Experts
fordexpert
Computer Links
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
