Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine
Hi! my washing machine wont start after the water is filled up thought it is on
  • 1 more comment
  • Anonymous Feb 09, 2008
    My wash Machine ran through all of the cycles but will not drain at the final rinse, could you please help
  • Anonymous Feb 22, 2008
    Kenmore Catalyst Top loading washer won't drain. Error code LO
    Help
  • Anonymous Jan 13, 2009
    My washer filled with water and would not go to next step of agitation. We tried the plugs and they work, even tried other cycles to see if that would make a difference. Still waiting on a solution.
I tried that already but it only does a 1/4 of a turn
Posted on Feb 18, 2008
There is a small tab or finger on the lid of your washer that pushes a button through a small opening on the washer as you close the lid. This is the spin safety shut off. It also will prevent the washer motor from starting "IF" the button is broken. It is plastic and will break over time due to vibration. With some experience you can remove housing to get access to the button. They can be purchased at local appliance repair shop. The job is easier than you think, and you can save the labor charges. That happened to me and I thought my washer was done.
Posted on Dec 14, 2007
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
Where is the reset button for a kenmore 80 washer wont stop filling water level
If this is a top loader then the vacuum line has come off of the dashpot or the water level switch is broken. UNPLUG the power-Standing in front of the washer, pry off the plastic trim strips on the left and right of the dash (control panel) Now you'll see a screw at the bottom where the strips mounted, remove ans KEEP the screws, now the dash will lift up and fold back, giving access to the parts.
Aug 17, 2014 | Kenmore series 80 Washer Motor 3363737-
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
Jul 07, 2011 | Kenmore Washing Machines
My Kenmore HD plus 80 series fills up tub slowly, starts cycle before its full.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 13, 2011 | Dryers
Kenmore hd 80 series,extra capacity plus. cold water will not fill tub?
heatman101
Jan 23, 2011 | Kenmore Washing Machines
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
132 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
