Question about Sony DCR-VX2000 Mini DV Digital Camcorder
DCR-VX2000 Power Issues
My DCR-VX2000 is not powering on. I'm not certain if this is a contact problem, lithium battery issue, or mechanical.
Are there known power issues with th DCR-VX2000? Mine is 6 years old.
  • dsouth Dec 21, 2007
    Hello I have the same problem as the post above. My Sony DCR-VX200 isn't powering up for some reason. I was watching a tape in it and shut it off to run an errand, came back and it wouldn't turn back on. I thought it might be the battery so I plugged it in but it still won't work on batt. or AC cord. I have tried leaving the batt. to charge over night and even hitting the reset button but nothing works and I REALLY can't afford the Sony flat rate repaor for this camcorder of $560. Can anyone help me with this, or at least give me and option on how to get the tape out with no power?
  • drewski6010 Feb 22, 2008
    We just bought this camera from a pawn shop. Luckily we have a 7 day warranty and can still take it back. We have found this same issue with our camera. Our camera will work while plugged in but doesn't want to take a charge. When we unplug the AC adapter, the battery life meter will read up to 57 minutes on the LCD, but then turn off after a few seconds. Anyone have a solution?
Pleeeeease pleeeeeeeeeeeeeease tell me if you guys fixed your vx2000s cuz im going through the exact same thing! i just bought off a friend and it hasnt worked once since i got it and i think its because of internal batterie problems or getting messed up in the mail but please respondd to this. pleassssse
Posted on Sep 17, 2010
Sony vx2000 japanese language problem
If you are experiencing a language barrier problem contact sony tech support at the link provided.They will help you in you language.
Welcome to Sony Support Get the help you need
Apr 30, 2014 | Sony DCR-VX2000 Mini DV Digital Camcorder
No playback after recording
check if you are using with a full battery..
if yes reset the unit and try again..
To reset the Camcorder, remove the battery from the Camcorder, press the Power button for 30 seconds and then reinsert the battery in the Camcder.
Dec 12, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
My camera doesnt allow me to take photos, the lens doesnt work.
Most of the lens issues due to mechanical problem. some of the causes are dropping the camera.
Hard shake like keeping the Camera in the hand and jump through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 Menu.
If the issue persists, perform a power reset of the Camera.
Performing a manual power reset Turn off the camera. Remove the battery pack. Remove the button-sized lithium battery. Allow the camera to remain without power for 30 seconds. Reinsert the button-sized lithium battery. Reinsert the battery pack. Turn on the camera. If the issue persist, service is required.
Jan 07, 2011 | Cameras
The lens on camera doesnt work
Hard shake like keeping the Camera in the hand while jumping through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 or Main Settings 1 Menu.
Jan 07, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
POOR COLOR QUALITY, NO MATTER HOW BRIGHT THE ROOM. SOMETIMES CAMCORDER WILL CATCH THE COLOR, THEN FADE BACK TO DIM LIGHT
I'm sorry that the video quality of the camcorder is poor. Sony camcorders will automatically adjust the shutter speed based on the lighting conditions. When video is being shot in low light situations, the camera will slow the shutter speed. This is normal operation and is not a service issue. To prevent this issue, record video in locations where more light is present.
You may use the White balance feature and check the operation. Refer the page 71 for more information. Refer the URL to download the Operating Guide:
http://www.docs.sony.com/release/DCRDVD105-205-305.pdf
You may also perform a power reset and check.
  1. Turn off the camcorder.
  2. Disconnect AC power adapter.
  3. Remove the battery pack.
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
Jan 04, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Screen goes black shortly after turning on
I'm sorry that the screen goes black shortly after turning on the camcorder. I suggest that you perform a manual power reset and check the operation. Follow the steps to perform a manual power reset:
Jan 04, 2011 | Sony Handycam DCR-SR42 Camcorder
Tapes recommended for DCR-VX2000? Also, How long c...
only 30 sec and play a blank cassette for 30 min
if needed repete three times not more
May 20, 2010 | Sony DCR-VX2000 Mini DV Digital Camcorder
My sony vx2000 shuts off at random times.Any ideas why it does that?
the power switch has met its end due to normal wear and tear. replace it at a service centre.
Jan 18, 2010 | Sony DCR-VX2000 Mini DV Digital Camcorder
Just sent in
To send where? If U want to send it to repair shop, no need to send battery along with.
Jun 09, 2008 | Sony DCR-VX2000 Mini DV Digital Camcorder
Dcr-vx2000 green viewfinder
ccd might be faulty. check with a service centre.
Mar 26, 2008 | Sony DCR-VX2000 Mini DV Digital Camcorder
Sony DCR-VX2000 Mini DV Digital Camcorder Logo
361 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
