hello..i have an acer 5600awlmi. Everything takes a long time to open although the computer is working fine and for some reason the built in mouse n keyboard are working slow. Also when some programs like I tunes dont open at all. This is getting long so lastly when i use a browser it gets stuck and i cant shut down normally so i have to press the power button!. ps ive already tried the built in recovery process for system default and the problem still occurs! thanks in advance!
Comments:
Sep 22, 2009
- Thanks for the reply. I tried the diagnostic startup thing but the computer stops responding when i try to change it to diagnostic setup and i have to turn it off manually. Also the previous setting is at Selective and not Normal! I currently don't have an antivirus installed but if it is a virus wouldn't it be removed when I restore settings to factory default? I will try to see if i can install spybot but I'm not too sure if i will be able to open it since some applications dont open.. thanks again for your help!
Assuming stock LT go to start run and type msconfig and click ok. On the general tab select Diagnostic Startup and click ok, it will ask to reboot and seleck ok. After the reboot see if it is operating normally.
If it is working normally then some application is causing the problem. You can selectivly choose to launch one app at a time till you find the one causing the problem. Most likely is antivirus set too agressivley or spyware. Might consider a tool like spybot to clean the system.
Hi! I want to connect laptop with audio amplifier via usb. I have a cable usb - (3 ends)cinch. how...
(More)
Hi! I want to connect laptop with audio amplifier via usb. I have a cable usb - (3 ends)cinch. how to do this?
Albania boy, te gjithe programet ne desktop me jane z'madhuar me shkronja dhe me figura se di cfare...
(More)
Albania boy, te gjithe programet ne desktop me jane z'madhuar me shkronja dhe me figura se di cfare te bej.
My blue tooth device is not working. When I try to install the blue tooth software the system...
(More)
My blue tooth device is not working. When I try to install the blue tooth software the system couldn't find any blue tooth hardware in my notebook. But according to the configeration there must be a bluetooth hardware in Aspire 5600 (my notebook) which can connect other blutooth devises. Please, send me some instructions.
