Question about Car Audio & Video
Clarion APA5240 5 channel Amp
I have a Clarion APA5240 amplifier. Its a 5 channel. I want to know the specs and how to wire this thing it has many switches/dials. I can't find any online info. I found this one place Herman electronics they have what I want but they want to charge me $80.00 for shipping a cd rom. NUTS
If anyone has info on the CLARION APA5240 I'll be a very happy man.
Thanks
  • Shawn Dec 15, 2007
    THANKS THANKS THANKS!!!!!!!
    ELECTROGUY YOUR THE BEST!!!!!
    This amp APA5241 has all the same funtions as my APA5240.
    Thanks So Much!!!!
    Sergeant:
    Champion:
  • 231 Answers
Try this it has worked for me in the past,..Contact Clarion by e-mail .Tell them your a student and learning electronics and in need of installation ,owners manual..ask if they can help and mail you info you need.Or try this link ..Its for a APA5241 could be very similar..http://www.clarion.com/us/en/MungoBlobs/720/1016/APA5241.pdf
Posted on Dec 15, 2007
S. No Brand Descripition Model Watts 1 Sony Music Player CDX - R3300S 52w X 4 2 JBL Front Compound System GTO 506 ce 5" Speaker - 165w 1/4" Tweeter - 55w 3 JBL Mid Range GTO 426 e 4" 2 Way - 105 W 4 Sony Rear Speaker XS - GT 6945 300 w 5 MTX Sub Woofer 6 Sony Amplifier XM - 444 4 channel 7 Sony Amplifier XM - 222 2 channel
my existing car audio which is fitted in a honda city doesn't have the punch. can anyone suggest me what amp should i upgrade to have good performance
Posted on Sep 29, 2008
Car amplifier just shut off and goes on and off when it wants
Driving the amplifier too hard causes it to go into protect mode to prevent damage. The amp periodically recovers and operates normally until the next overdrive peak hits it.
Apr 21, 2014 | Clarion Car Audio & Video
Fuse apx200m
HI,
If the fuse is blowing of then there is problem with the inverter stage of amplifier. There is an inverter stage in the amplifier to boost the 12V to + or - 30 to 40V normally. Its a switching circuit normally uses Mosfets and ferrite core transformer and a driving IC. If the mosfet is shot then the fuse will blow off immediately after power is connected.
Check on thing remove the REM connection and then connect the power. If the fuse blows the there is fault with the Mosfet Its short.
If the fuse blows only when you connect the REM then the amplifier stage is faulty.
Also check by disconnecting the speakers. if any of the speaker is faulty then there is a chance for fuse blow off.
Ajin
Apr 27, 2012 | Clarion APX280M 2-Channel Car Amp
Why does the Clarion 2001 have a left and right channel input if the output is mono?
reason is there is separate bass on both input channels that you want to include in the sub channel. For example, if bass drum is on left channel and bass guitar is on right channel, you need both to hear all of the bass music from your single sub. OK?
Dec 11, 2010 | Clarion APA2001 Car Audio Amplifier
Hello. I have an Ultra Linear Amp - UL724 model. I am wiring it up to play in 2 channel mode - in stereo. I can only get one channel to work - the left... I swap the rca cords, still only the left side...
YOUR METHOD OF TROUBLESHOOTING USING THE PROCESS OF ELIMINATION IS RIGHT ON AND PERFECT. IT INDICATES A BAD AMPLIFIER CHANNEL. I KNOW THIS SOUNDS ODD, AS YOU HAVE TWO OF THESE NOW. IT IS RARE, BUT I HAVE SEEN INPUT CONFIGURATION SWITCHES WIRED BACKWARDS, SO THE ONLY THING LEFT TO DO IS TO HOOK UP THE BAD CHANNEL TO ONE SPEAKER ONLY, BY ITSELF. THEN TAKE ONE RCA ONLY AND PLUG IT INTO ONE RCA INPUT AT A TIME. THEN MOVE THE INPUT SWITCHES AND REPEAT THIS PROCEDURE UNTIL YOU HAVE TRIED ALL SWITCH COMBINATIONS AND ALL INPUT JACKS. WHAT YOU ARE TRYING TO DO AT THIS POINT IS TO DETERMINE IF THERE IS ANY RCA JACK WITH ANY SWITCH POSITION, THAT WILL ALLOW YOU TO GET OUTPUT FROM THAT CHANNEL. IF AFTER THIS TEST, YOU STILL HAVE NO OUTPUT, THEN NO MATTER HOW ODD, IT WOULD INDICATE THAT YOU DO IN FACT HAVE A SECOND DEFECTIVE AMPLIFIER. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 07, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
The amp is on lock mode and i do not know how to take it off
Hello, Could you please specify what type of clarion amp you have and what happend prior to the problem? I don't know what you mean by lock mode unless it has some security feature or you mean it's in protect mode. If it's in protect mode more thanlikely you have power supply mosfets shorted or output transistors shorted. If all wiring and speakers are good and your head unit. Let me know.
Aug 25, 2009 | Clarion Car Audio & Video
Wires
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
Clarion vrx935vd
Do you have an external amplifier for all your speakers?
If you answer is yes, you need to check the remote wires,they may be connected in the wrong place.
the wire for the amp's remote is the BLUE/WHITE STRIPE.The BLUE (only) wire is for the pwr antenna,in other worlds if you connected the pwr antenna wire to the the remote in to the amplifiers,every time you insert a cd,your unit will swtich to cd mode and will turn the pwr antenna voltage off.
Just switch the wires.
Dec 02, 2007 | Clarion VRX935VD Car DVD Player
I need help
Make sure your ignition signal wire didn't come loose somewhere. Was the Amp exposed to extreme heat?
Jun 19, 2007 | Clarion APX2120 2-Channel Amp - 120W 180W...
Noise coming thru speakers
may be the ground of the rca or in your stereo. and many times in the inlet of the amp. good look.
Feb 09, 2007 | Clarion ProAudio APA4320 Multi-Channel Amp...
Car Audio & Video Logo
2,352 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
