Back to:
Tags:
Hampton Bay 24750 Huntington III Ceiling Fan
Hampton Bay 326-946
posted by starzz on Dec 14, 2007
I cannot find my model Hampton Bay Raleigh 111 model 326-946.
I went to change the light bulb,heard a buzzing sound as if it shorted out. The light no longer works, However the fan does. When I pull the change on the fan. a second time the lights come on for about 30 seconds and go out again.I called home depot, they really didn't want to bother with this problem and said it was my wiring. If this was true why does the fan still work? If I call a electrician he will charge me more than the light cost. I had a certified electrician install it the first time.
What should I do? Is this possibly a defective problem or do I need an electrician
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 26, 2008
Not Rated (0)
LauriStG
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Chances are the wire nut came off the connection for the light unit. If you're handy, shut off the fan mechanism at the fan (pull chain until fan is off), then turn off the power at the breaker box, ensure the power is off at the light switch and proceed to unscrew the fixture from the mounting unit (attached to the ceiling).
Carefully support the fan unit with one hand ( there should be a silver grounding wire that will help support the unit - unless it wasn't installed properly in which case the unit will be heavy - try to balance on the ladder if it's tall enough). Look for the white and black wires - one will be for the fan unit, one for the light unit.
Check to see both are securely attached by wire nuts. If one is loose or has come apart, carefully re-twist the wires tight (turn to the right as this is the way the wire nut twists on so it will stay together when you replace the wire nut. If when you replace the wire nut the wires are still loose, replace the wire nut - they do get old and tired.
At this point I would turn on the power at the breaker box and turn on the switch for the fan on the wall. Then try the light unit - see if that fixed the problem. If it has, turn off power again, replace the unit the same way you took it down - if not, there is a problem in the internal wiring . . . check with warranty depot.
Hope this helps,
Lauri
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hampton Bay 326-946:
I don't want to Accept this solution
Can you Help with these Electric Fans problems?
Hampton Bay 24750 Huntington III Ceiling...
I'm purchasing 2 model 24750 hampton Bay fans. I need the...
I need a new Blade for my Huntington III do you know were...
My fan was working in the morning I turned it off. I came...
The light works and all of a sudden the fan stopped...
I have no reverse switch located on my Hampton Bay fan. Is...
Loading problems.
Repair Service
Find Electric Fan Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
