AHEM!! Could you explain a little more clearly what it is that you need help with. You have posted under Lawnboy Push Mowers asking about a tecumseh (I assume you mean Peerless) gearbox for ride on
There is an official Tecumseh/Peerless motion drive system manual available, which deals with the strip-down and rebuild of all current and recent transmissions. Parts availability MAY be a problem, however, not to mention that internal transmission parts are EXPENSIVE. A set of shift keys and bearings + time will just about equal the cost of a new transmission.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Tecumseh Lawn Boy Push Mowers
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series...
Suddenly stopped then could not pull mower backwards because rear wheels would only go forwards, and...
(More)
Suddenly stopped then could not pull mower backwards because rear wheels would only go forwards, and mower would no longer start
I replaced the spring on the Air vane and know how to adjust it but do not know how much tension to...
(More)
I replaced the spring on the Air vane and know how to adjust it but do not know how much tension to put on it. The mower seens to be running rich and the throtle does not change the speed much at all.
Hello, looking for the proper adjustment procedures for the throttle linkage and the governor lever....
(More)
Hello, looking for the proper adjustment procedures for the throttle linkage and the governor lever. TVS90 43544K 3014J Thanks
tecumseh vantage 35 manual I have a Dellorto FHC 20 carburettor on a Tecumseh Vantage 35 tiller. I...
(More)
tecumseh vantage 35 manual I have a Dellorto FHC 20 carburettor on a Tecumseh Vantage 35 tiller. I think I have a linkage or spring missing. Can anyone provide a photograph of the finished unit or an exploded view of the carburettor. thanks. mar
