Hi, I want to add memory to my Acer L3600 and want to know how to get into the unit to add this.
It's easy to remove the external cover but how do you get to where the memory should go? It's baffled me.
Thank you.
There should be two card slots on the motherboard,they have white locks on each end,push down on both sides to remove ram stick,should have two or four slots all in a row depending on the motherboard,they may be empty,thats where the new memory goes,takeing apart the case can be tricky.hidden screws under stickers or rubber feet or bumpers ,may have to remove entire motherboard to see on the back side,good luck hope this helps
Testimonial: "Quick reply."
Thanks todd0708.
I need slightly more specific instructions to gain access where the ram slots are & hope others will post here with a solution.
Thanks again.
