Question about HP LaserJet 2840 All-In-One Printer
2840 printer 50.1 & 50.2 error dometimes 13.0 error
2840 all in one printer 50.1 & 50.2 error dometimes 13.0 error
  • 1 more comment
  • MsJoy Dec 27, 2007
    After every two copies the Fuser Error 50.1 message comes on and it says to turn the computer on and off. I do and get two more before the error message occurs again.
  • Anonymous May 12, 2008
    I have
  • Anonymous Jun 14, 2008
    50.1 Fuser Error
  • 3 Answers
Thanks CoolDragon. Ifollowed your advice and eventually replaced it.
After trying to pull out and reseat the fuser a few times (I would even get one or two prints out of it each time), I finally ordered another fuser and problem has gone away. I did google and purchasing site searches (pricegrabber, pricewatch, etc) and found a decent priced site, that also gave discount for your returned bad unit (they gave you so many days to return it), otherwise they'd charge your credit card for the extra dsicount they had origanlly given.
Posted on Jul 04, 2008
    Sergeant:
    Champion:
  • 317 Answers
Your fuser is shot.... try the following or replace it:
50.x Fuser Error Description The device has experienced an internal hardware error.
  • 50.1 Low Fuser Error
  • 50.2 Slow fuser error
  • 50.3 High fuser error
  • 50.4 Fuser drive error
Recommended Action
  1. Turn off the device, and then disconnect the power cord.
  2. Remove the fuser and then wait at least 20 minutes. To do so, complete the following steps.
    NOTE: These instructions can also be found in the User Guide (c00292207) for this product.
    1. Turn off the device, and then disconnect the power cable.
    2. Rotate the locks on the fuser to the unlocked position, see the Figure below. Figure 1: Location of Fuser Locks 2840 printer 50.1 & 50.2 error dometimes 13.0 erro - c00685504.jpg
    3. Grasp the fuser handle and pull the fuser assembly from the device, see the Figure below. Figure 2: Fuser Handle c00685505.jpg CAUTION: The parts on the internal surface of the fuser are very hot. To avoid being burned, do not touch those parts.
    4. Using both hands, slowly and steadily remove any print media from inside the device. Then, carefully reinsert the fuser and secure the locks.
    5. Reconnect the power cable, and then turn on the device.
  3. Wait for the device to initialize.
  4. If the error persists, replace the fuser assembly.
  5. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Click here to go for more information about contacting Hewlett-Packard.
Posted on Dec 14, 2007
THE ROTATE BUTTON IS NOT WORKING TO PUT THE INK IN PROPERLY. WHY?
Posted on Dec 08, 2008
Can u help me my 2840 laserjet paint error 54.2 ..rotating to mageta ?
if its error comes on only margenta toner, so it is posible that the toner powder senser sence no ink, but counter says there is remain some,
1 trick replace the toner
2 trick go to printer menu -> servises -> restore factory
Apr 03, 2015 | HP LaserJet 2840 Printer
Hp laser jet 2840 Error 59.99
T2 Clutch error: Check the cable
connections to the DC controller. If the error
persists, remove the imaging drum and
check the clutch. If the error persists,
replace the T2 clutch. If the error still
persists, replace the DC controller
May 26, 2012 | HP LaserJet 2840 Printer
Show picture of carousel rotary for hp 2840
Carousel rotation motor error, only professionals can do this activity,, Pl submit the unit in service center,, online support not suggestible..
Nov 16, 2011 | HP LaserJet 2840 Printer
I am getting scanner error 5 massage on hp 2840
A tech needs to look at it. It could be as easy as just reseating the 4 wire bundle connector that comes off the scanner and connects to the formatter.
But, in any event a tech has to check it out.
Jul 29, 2010 | HP LaserJet 2840 Printer
My hp 2480 has an error message 10.1004
the #10 error codes are supplies memory errors, it's saying toners installed don't match what's in the memory. Could be dirty contacts or generic toners.
Sep 29, 2009 | HP LaserJet 2840 All-In-One Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Laserjet 2840 has error 59.4 have reset power several times but error returns when it tries to print
laserjet 2840 has error 59.4 have reset power several times
Nov 07, 2008 | Office Equipment & Supplies
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
HP 2840 "Engine Error"
engine error is the fact the the printer isnt turning, also may have a fault in one of the circuit boards.
Jan 05, 2008 | HP LaserJet 2840 Printer
Replace Cathridge
The front panel tells you witch toner cartridge should you replace. If a supply memory error ocures then the cartridge should be replaced or exchanged with a new one. The imaging drum unit is also consumable. for "Joe 50" - there are 4 toner cartridges in the printer.
Dec 28, 2007 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
4,431 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
