The printer seems to be feeding ok but the print job comes out strealy (horiziontal incomplete words) Not sure whether this is a cartridge probelm or a printer problem? Can anyone help? The paper I am using is standard A4 print quality paper... Thanks!
Comments:
Sep 21, 2009
- Thanks - it is a wireless printer though. I will still go through and try and refresh the driver (I hope I can find the CD!)
this could also be as simple as going in to your device manager and refreshing the driver first, unplug the printer from power and PC, reboot pc and then power up printer let it go threw its motions and then once the pc is completely booted connect the the usb cord and try again, you may also have a bad cord
My printer will not print. In fact, across the screen it reads, "Print Cartridge Problem: At...
(More)
My printer will not print. In fact, across the screen it reads, "Print Cartridge Problem: At least one of the cartridges has a problem" I have changed out both cartridges and still this is the case. It printed fine last week and when I came into the office today, it is now reading this. Estimated ink values will not calculate so it seems to be in limbo and not able to read the remaining amounts. I've cleaned both copper ink heads on the ink cartridges. I have also unplugged the printer completely from the computer and outlet. Please help!!
I have a J4680 all in one printer with fax, copy print and scan capabilities and have the fax hooked...
(More)
I have a J4680 all in one printer with fax, copy print and scan capabilities and have the fax hooked up to my home phone it rings but someone was suppose to fax something and it was turned but no fax came in what is wrong???
