Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Don't get it
Just bought a new quadra d2 500 Gb (already have three LaCie HD plugged into my G5) but the mac at first didn't want to recognize it : I tried daisy-chaining it through FW800 then direct FW400 but still doesn't mount on the desktop. I tried then to daisychain it through FW400 and now the computer tells me that the volume can't be read by my mac giving me three options :
I obviously pressed initialize, the disk utility open but don't let me do anything else then erase the disk.
After what I read on the user guide, LaCie HDs don't look so macfriendly to me!!!
So should I go further and erase or should I send it back as it's the first time I use it?
  • Anonymous Jan 10, 2008
    I have the same problem. I had problems connecting it at first. I was using an Airport Extreme. I bought a multiple hub. I turned it on one day, and it was there, I put my photo library on it. A few months everything going well. And now I can't find the LaCie on my desktop. Although I can find photos from a month ago.  I am at a loss of what to do. I disconnected everything and then connected everything again. and still nothing. Any ideas? I have a MacBook Pro that I bought last September.
  • 556 Answers
I notice that you had issues initially installing the drive. Is it possible hat your actions as noted in the link corrupted the HFS+ formatting that was shipped on the drive?
Review this link
If as you noted THIS WAS THE FIRST TIME YOU USED THE DRIVE, you have no data on the drive to loose or recover.
Especially if you believe your actions may have corrupted the formatting of the drive, reformatting may be the appropriate response and could yield a working drive eliminating many return headaches. However if this does not seam reasonable contact with LaCie as to why the drive did not work directly out of the box may be appropriate. (I did confirm in the drive specs that the drive should have been formatted correctly for an apple computer -- windows users need to reformat the drive before they can use it )
I hope this helps
Posted on Dec 14, 2007
LaCie d2 Quadra is inert: service/repair or buy new one?
Check with LaCie's support site at and it's a good idea that you write down the serial number of your external disk.
Jul 09, 2010 | LaCie (300770) 250 GB Hard Drive
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
I am trying to format my lacie 4big quadra raid drive for FAT 32 so that I can use with Mac and Windows. My windows machine won't recognize it so I am not able to format and use with both Mac and Windows....
You cannot format a 4GB drive ALL under FAT32, it is NOT mathematically possible IT will be possible to Break Up the drive into Partitions, and then Format them FAT32. You need to keep each partition under 1GB.
Mar 13, 2010 | LaCie 4big Quadra 4000 GB
My LaCie 500GB Quadra spins and clicks. Have tried (Mac) DiskWarrior and Disk Utility, but the drive ignores them and spins, clicks, and the blue light flashes
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Sep 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Not showing up on my desktop
I had this same problem. I you are experiencing this problem and you have a Mac. Go to the LaCie web site there is a firmware update for this drive. Download the firmware update application from the LaCie website, start it and follow the directions. It should fix the problem.
Jan 27, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Help please -LaCie D2 Quadra
Take a look at this link and see if it helps -
Jan 07, 2008 | LaCie D2 Extreme 300 GB Hard Drive
Installed on MAC, then Plugged it to PC, now MAC won't recognize Drive
look into Disk Warrior...its a hundred bucks, but it is a miracle worker of sorts and might fix everything for you.
the frustrating thing about DW besides its $100, is it takes less than a minute to fix problems I would fret over for weeks
Dec 29, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
179 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
