Question about Mitsubishi VS-50605 50" Rear Projection Television
I have a Mutsubishi 48" rear rpojection tv. I have a two crowns in the picture. one on top looks like a smile and one on bottom like a frown. after about 30min of tv on sometimes if you hit the side of tv it will all straighten out. Is this a loose conection? if so where do I start to look?
  • 87 Answers
You probably need to re solder the convergence output IC`s. They will be mounted vertically on a large aluminum heat sink. You can also tap gently with the plastic end of your screwdriver on the PC board to find the area where it is most sensitive. Visually inspect the bottom side of the board for noticeable rings around the solder points. Good luck
Posted on Dec 14, 2007
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
How do i fix the convergence on my 48 ws mitsubishi tv? the red will not converge and is jumpy
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
Apr 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi VS-1561
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV.   Take off your screen and screen protector and safely set them aside.
Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set.  It will look like new. You need to do this at least once a year.
Jan 05, 2009 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Apr 19, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Need replacement screen for Mits. WS-48511
The other site i am associated with has used screens for mitsubishi you just have to post the measurements of your screen top to bottom and side to side dont include the frame size as we allow 1/4 inch for fitting in the frame just need the size of the screen to the frame edge.
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
you need to do self test first look in threads and also to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
Sony kp-48v75 picture arcs at top and bottom
Convergenc IC proble look for and replace all Stk392-XXX
Dec 03, 2007 | Sony KP-48V75 48" Rear Projection...
Colored Lines at the top of the picture
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 19, 2007 | Mitsubishi WS-48513 48" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
