Question about Pioneer DVL-919 DVD Player
Pioneer DVL-919 DVD door does not open
Hi.
I have a Pioneer DVL-919 Laserdisc player and door does not open.
Is there a common fix for this?
Is it an easy and inexpensive fix?
Thanks!
You can also try flipping the player upside down and shaking it a little. I bought a DVL 909 and when it arrived the tray wouldn't open. The seller told me to try that, and it actually worked. I wouldn't recommend shaking it quite so much as this video shows... but it does show that it can work.
Posted on May 11, 2010
    Sergeant:
    Champion:
  • 285 Answers
Well usually when these draws dont open can be one of 4 things. First is to check if there is anything jammed, place your ear near the dvd draw area and press eject and hear if there is a sound.. if it sounds like the motor is struggling it will buzz .. or if its a low humming sound this means the belt has snapped and the motor is working, if nothing is heard, a connection could have come loose from the motor or the Motor Control Chip on the circuit Board might be shorted or the motor itself could be dead.
All these problems are what can possibly fault the dvd/cd draw.
And Depending on the issue, its an easy fix if the belt or the motor have become faulty.
hope this helps
Posted on Dec 14, 2007
Hi, I need a pioneer dvl-909 service manual that tells how to replace the loading belt. Thanks, Bill
Try to see if the drawers are blocked by something either inside or outside of the case.
Mar 17, 2012 | Pioneer DVL-909 DVD Player
Pioneer DVL-700. Unit Plays LD Discs & CD's fine but will not play any DVD Videos.
The dvd's are not spinning up correctly. If the belt inside is worn this will cause cd's to play but dvd's fail. open up and replce belt (small black rubber running on motor)
May 11, 2011 | Pioneer DVL-700
Looking for a manual for the DVL-919. Running it though a Onkyo TX-NR807 AV receiver and it keeps defaulting to monochrome.
okay check electromaniacs.com for a free copy.or partstore.com to buy one which ever you choose.good luck
Feb 28, 2010 | Pioneer DVL-919 DVD Player
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
DVL-V888
You need to remove the cover and expose the area where the motor sits close to the front, you will find a broken belt, replace that, if you can't get to the screw to remove the assembly, use your fingers or screwdriver to turn the cog so that the drawer is manually opened. make sure power cable is unplugged first.
Jul 26, 2008 | Pioneer DVL-V888 DVD Player
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Tray won't open
It could be electrical or mechanical. Without checking there is no way to be sure. You can get the service manual for your model for 10.00 at the following link. That should get the problem taken care off.
http://www.electronicsrepair.net/dvd9.shtml
Pioneer DVL-919 DVD Player Logo
790 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
