Question about Tomtom ONE GPS Receiver
The installation poster is not very useful
Dears,
The windshield mount seems to be essentially rigid. Once installed shouldn't it be able to swivel / twist so I can angle it correctly for easy viewing.
Kindly help…Mahesh
    Scholar:
  • 143 Answers
There are knobs on the horizontal & vertical mount on the old tomtom one's, if you loosen them by turning them anti-clockwise you can then set the desired position.
On the newer models there is a ball joint allowing for adjustment.
If you have a rigid mount then you can try your local dealer to purchase a different one.
Posted on Dec 16, 2007
Where do I mount my radar detector?
The unit comes with a windshield mount - assemble the bracket ( if needed) and secure to a location on the windshield. Make sure its above the wipers and not behind any metal. Once installed, make sure that the radar detector is LEVEL WITH THE ROAD! This may require bending the bracket to level the unit. (Note: remove detector while adjusting the bracket).
Dec 28, 2015 | 14 Band Radar Laser Detector Voice Alert...
What are some key tips for the selection of pretty much all kinds of posters?
1) Have a look at your current room. What does your current room look like and which posters could you use to turn this boring room into an exciting room? Aspects such as room color, design, and style play a significant part when it comes to selecting Wall posters. For instance, a modern room should in most cases have well matching posters if the design is important to you. Framed kinds are mostly preferred by adults.
2) Once you have figured out and decided the type of wall decoration you want to add, it is now time to start decorating your room with proper posters. Give yourself enough time to finish the decorating process.
Modern posters include types such as Selena Gomez posters, horse posters, car posters etc. Nowadays, you can get paper prints with literally any motive or individual who really made a difference in the world. Think about the individuals who had the biggest influence in your own life. If you have a modern living room or want to surprise your kids with something really unique, huge wall posters that feature individuals or objects they love may be the way to go.
3) Make sure to install the accessories on the right spot. In most cases, it is recommended to install posters on walls where those are good visible. When it comes to fan rooms or recreation rooms there are usually no strict limits for installing posters. Here kids love to have accessories which remember them on people they love and appreciate literally everywhere.
Sep 23, 2015 | Canon PosterArtist 2008
Water Ridge kitchen faucet model FP4A4107NP does not swivel between sinks. I thought they all could be directed into either side of a double sink?
Did you install the faucet without using the top mounting plate? This could cause no spout swivel.
Dec 26, 2014 | Plumbing
How do you replace windshield wiper motor on a 1997 ford e250 van
REMOVAL
  1. Raise and support the hood.
  2. Remove the windshield wiper pivot arms.
  3. Remove the cowl top vent panels.
  1. Disconnect the windshield wiper mounting arm and pivot shaft.
  1. Remove the access cover from the dash panel.
  2. Remove the mounting arm and pivot shaft retaining clip.
  3. Disconnect the windshield wiper mounting arm and pivot shaft from the windshield wiper motor.
  1. Remove the windshield wiper motor.
  1. Disconnect the electrical connector.
  2. Remove the three bolts.
  3. Remove the windshield wiper motor.
INSTALLATION
  1. Install the mounting arm and pivot shaft retaining clip on the windshield wiper mounting arm and pivot shaft.
  1. Install the windshield wiper motor.
  1. Place the windshield wiper motor in the dash panel.
  2. Install the three retaining bolts.
  3. Reconnect the electrical connector.
  1. Reconnect the windshield wiper mounting arm and pivot shaft.
  1. Press on the windshield wiper mounting arm and pivot shaft after it is aligned with the windshield wiper motor.
  2. Install the access cover in the dash panel.
  1. Install the cowl top vent panels.
  2. Install the windshield wiper pivot arms.
  3. Adjust the windshield wiper pivot arms.
This is technically for the V6 4.2L but I'm sure those Ford E250's have the same setup for windshield wiper motor. Let me know how it goes.
Nov 17, 2014 | Cars & Trucks
We have a flexible 1 1/2" line on our tub. Can the heater be installed on a flexible line?
Yes bath heaters may be installed on flexible PVC tubing. it is essentially the same as rigid PVC piping but has flexible properties.
Feb 12, 2011 | Jacuzzi S750000 Black RapidHeat In Line...
How to change the alternator on my 2000 grand voagear
This is for a 3.3L motor
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
REMOVAL
  1. Release hood latch and open hood.
Removal/Installation of Battery Cables 81929864
  1. Disconnect battery negative cable.
  2. Remove windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  3. Remove accessory drive belt.
Generator Mounting Bracket 81929870
  1. Remove bolt holding top of generator mount bracket to engine air intake plenum.
  2. Remove bolts holding outside of generator mount bracket to generator mount plate.
  3. Remove bolt holding top of generator to mount bracket.
  4. Remove generator mount bracket from vehicle.
  5. Rotate generator toward rear dash panel.
Generator 81929868
  1. Disconnect the push-in field wire connector . from back of generator.
  2. Remove nut holding B+ wire terminal to back of generator.
  3. Separate B+ terminal from generator.
Generator Pivot Bolt 81929871
  1. Remove bolt holding bottom of generator to lower pivot bracket.
Generator 81929872
  1. Remove generator from vehicle
INSTALLATION
  1. Place generator in position on vehicle.
  2. Install bolt to hold bottom of generator to lower pivot bracket.
  3. Place B+ terminal in position on generator.
  4. Install nut to hold B+ wire terminal to back of generator.
  5. Connect the push-in field wire connector into back of generator.
  6. Rotate generator forward away from dash panel.
  7. Place generator mount bracket in position on vehicle.
  8. Install bolt to hold top of generator to mount bracket.
  9. Install bolts to hold outside of generator mount bracket to generator mount plate.
  10. Install bolt to hold top of generator mount bracket to engine air intake plenum.
  11. Install accessory drive belt.
  12. Install windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  13. Connect battery negative cable.
  14. Verify generator charge rate.
Jan 02, 2011 | 2000 Plymouth Grand Voyager
How do I attach a review mirror for a 1994 thunderbird lx
Go to an auto parts store and buy rearview mirror adhesive. Your rearview mirror will separate from the small mounting piece that adheres to the windshield. Clean off the glass where it will sit. Follow the directions on the adhesive package and install the mount on the windshield. Once it dries, install the mirror on the mount. Rearview mirror adhesive is one of the most powerful adhesives on the market. Don't use anything but rearview mirror adhesive or the mirror will not hold.
May 21, 2010 | 1994 Ford Thunderbird
Installing windshield mount
there are two pieces to the mount, the mount and the cradle..the cradle snaps on the gps and the mount slides in the groves on the back of the cradle.
to attach it to the window, lift the lever near the suction cup on the bottom of the mount..press firmly against the window, the push lever down toward the windshield to lock it.
you should remove it and reattach it every few weeks to prevent it from falling off the window and damaging the unit.
bill
Feb 28, 2010 | Magellan RoadMate 800 GPS Receiver
The wiper motor on my 1983 Ford Ranger still works but the wipers no longer move. I think there is a failure of the mechanical linkage. Where do I go to find repair parts?
why do you think the motor still works if the wipers don't move? Can you hear the motor run or can you see a little movement when you turn the switch on?
What happens when you activate the washers?
go to a salvage yard that allows you to remove the parts yourself. Then you can see how the motor and linkage assembly comes out.
don't have 1983 info, but here is 1994:
Section 01-16A: Wiper and Washer System, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
DESCRIPTION AND OPERATION Windshield Wiper System, Ranger/Explorer The windshield wipers are actuated by a permanent magnet, rotary-type electric windshield wiper motor (17504) . The two windshield wiper pivot arms (17526) and windshield wiper blades (17528) are mounted on a pivot shaft, one at each side of the windshield. The windshield wiper mounting arm and pivot shaft (17566) are connected to the motor by windshield wiper adapter and connecting arm clip (17531) . Ranger and Explorer vehicles are equipped with an interval wiper and washer (IWW) system featuring a lever-type turn signal and windshield wiper switch (13K359) mounted on the steering column. The IWW windshield wiper governor (17C476) uses a relay contact to control current to the windshield wiper motor . The governor electronic circuitry controls the contact to supply current to windshield wiper motor . A rear wiper/washer system is available on Explorer vehicles. The rear window wiper system consists of a windshield wiper motor mounted inside the liftgate (40010) , an articulating windshield wiper pivot arm and windshield wiper blade , a windshield wiper/washer switch (17A553) and an inline circuit breaker. The front electric windshield washer system consists of a control switch, integral with the turn signal, a windshield washer reservoir (17618) and windshield wiper motor and the necessary windshield washer hoses (17A605) , windshield washer nozzle jet and brackets (17603) and attaching parts.
Pivot Shafts and Linkage Removal and Installation
NOTE: The left and right pivot and windshield wiper adapter and connecting arm clip assemblies are serviced separately.
  1. Perform Steps 1 through 9 of Windshield Wiper Motor Removal as described in this section.
  1. If servicing left windshield wiper adapter and connecting arm clip , remove left windshield wiper mounting arm and pivot shaft and windshield wiper blade assembly.
  1. Remove left windshield wiper adapter and connecting arm clip access cover.
  1. Remove left pivot nut, lower windshield wiper adapter and connecting arm clip and slide it out through left access opening. For installation, follow removal procedures in reverse order. Tighten nut to 10-13 Nm (7-10 ft-lb). Make sure the clip is fully seated in the windshield wiper adapter and connecting arm clip . Do not try to install clip with windshield wiper adapter and connecting arm clip on motor crank pin.
Windshield Wiper Motor Windshield wiper motor are not serviceable. If worn or damaged, the windshield wiper motor must be replaced as an assembly. Removal
  1. Cycle windshield wiper blades until in straight-up position and turn ignition switch OFF.
  1. Disconnect battery and wiper motor electrical connector.
  1. Remove the right windshield wiper mounting arm and pivot shaft and windshield wiper blade .
  1. Disconnect the battery ground cable (14301).
  1. Remove the right pivot nut and allow the windshield wiper adapter and connecting arm clip to drop into the cowl top outer panel .
  1. Remove the linkage access cover, located on the right side of the dash panel near the windshield wiper motor.
  1. Reach through the access cover opening and unsnap the wiper motor clip.
  1. Push the clip away from the windshield wiper adapter and connecting arm clip until it clears the nib on the crack pin. Then, push the clip off the windshield wiper adapter and connecting arm clip.
  1. Remove the windshield wiper adapter and connecting arm clip from windshield wiper motor crank pin.
  1. Remove nut and ground strap.
  1. Remove three attaching nuts from windshield wiper motor. Remove the windshield wiper motor .
Installation
  1. Position the windshield wiper motor and install the three attaching screws. Tighten to 13.6-19.0 Nm (10-14 ft-lb).
  1. Install nut and ground strap.
  1. Connect wiper motor electrical connector.
  1. Install clip completely onto right windshield wiper adapter and connecting arm clip. Make sure the clip is fully seated. Do not put the windshield wiper adapter and connecting arm clip on the motor crank pin and then try to install the clip.
  1. Install the left windshield wiper adapter and connecting arm clip onto the wiper motor crank pin.
  1. Install the right windshield wiper adapter and connecting arm clip onto the wiper motor crank pin. Pull the windshield wiper adapter and connecting arm clip onto the crank pin until it snaps into place. The clip is properly installed if the nib is protruding through the center of the clip.
  1. Install the right windshield wiper mounting arm and pivot shaft and nut. Tighten the nut to 9.5-12.5 Nm (84-110 in-lb). NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
  1. Connect the battery ground cable and turn the ignition switch on. Turn turn signal and windshield wiper switch off so windshield wiper motor will park, then turn ignition switch off. Replace right windshield wiper adapter and connecting arm clip access cover.
  1. Install the windshield wiper mounting arm and pivot shaft and windshield wiper blade assemblies on the pivot shafts to dimension X. Dimension X is the distance between the centerline of the blade saddle and the top edge of the cowl top outer panel grille. The value of Dimension X for each vehicle is given in the Dimension X chart in the Specifications portion of this section.
  1. Test the system.
Jan 04, 2010 | 1983 Ford Ranger
Logitech Quickcam Orbit AF swivels and picture freezes
I used to have the same problem. Uninstall the software and then download and install the latest version from logitech. Make sure you unplug the cam before installing the updated software.
Jan 14, 2009 | Logitech QuickCam Orbit AF Webcam
Tomtom ONE GPS Receiver Logo
32 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
