I have a Compaq Presario 900. The LCD screen used to work fine, now I am getting nothing. Prior to...
(More)
I have a Compaq Presario 900. The LCD screen used to work fine, now I am getting nothing. Prior to this, I was getting vertical lines on the screens display and then it turned a like red in color. Then I powered it back up a day later and it was fine no distortion in color nor the vertical lines on the display. Then I tried to power it on for additional use the following day and then there was no display at all? For a minute I was getting a very dim flash of light on screen and no display. Now I am getting nothing at all. I was wondering could this be the lcd backlight or the lcd inverter? I have tried connecting it to an external monitor and there was no display on the external monitor neither. I was getting a display on the external monitor when the laptops screen display was functional?
Eddy Debaene / Belgium
eddy.debaene@telenet.be
Ik krijg steeds de melding "Uitgebreid...
(More)
Ik krijg steeds de melding "Uitgebreid serviceplan" met 3 keuzemogelijkheden, en kan dit venster NIET sluiten. Het venster komt steeds terug, welke keuze ik ook aanstip. Zéér vervelend !!!!!!!!!
When i connect the laptop to the power outlet it shows only the battery light and the light that...
(More)
When i connect the laptop to the power outlet it shows only the battery light and the light that shows the connection to a power outlet. But when i push the switch nothing happens and its light shows nothing.
Purchased a new screen (old one got broken) from Ebay but screen only turns white when power laptop...
(More)
Purchased a new screen (old one got broken) from Ebay but screen only turns white when power laptop on. Tried laptop connected to PC monitor in safe mode and worked ok. The seller said the screen is compatible but it looks alot different on the back of lcd screen from the original (where it is green vs white).
I replace the screen and now it will only come on with the power cord attached. The screen only...
(More)
I replace the screen and now it will only come on with the power cord attached. The screen only shows white. I followed the book exactly. I replaced it the same screen. Will the connector going to the screen go in both ways?
