Question about Acer Aspire 5630 Notebook
A problem has been detected an window has shut down to prevent damage to my computer
The disk space appears to be used up because i was installing some software when the computer shut down. Now the message reads dump of physical memory is complete and I can't start up computer.
  • 49 Answers
Boot into safe mode by pressing f8 at windows boot time,
run a check disk by rightclicking the harddisk, properties, tools, check disk
check both options for file recovery and system file fix, click ok rebboot
see what happens and get back to me
or
use a bootable media like the windows system disk to enter the recovery console and run checkdisk from there
get back to me
Posted on Dec 15, 2007
Message displayed- problem detected and windows has shut down to prevent damage. Restart using safe mode-tried this but it did not work. Tech Information STOP OXOOOOOOED Unmountable-_Boot_Volume
If this is a corruption it may be fixable, again this depends upon your version of windows, however please be aware this may be a corrupt hard drive so you may need to replace this and reinstall.
Try this first
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
May 11, 2011 | Dell Computers & Internet
"A problem was detected and
Re boot in safe mode if normal boot is not possible and run CHKDSK/F
DO NOT DISABLE ANTIVIRUS!!!!!!
That should sort hard disc errors out then download iobit.com and run the registry utility, that will remove more errors. It is a free ware programme and works very well.
Hope that sorts it out for you.
Feb 26, 2011 | Computers & Internet
Can't get vista computer to boot up safe mode doesn't work. when computer reboots goes to launch start up repair which leads to "a problem has been detected and windows has been shut down to prevent...
Any Microsoft Vista CD/DVD disk can be used to run the "repair" application,
or to totally re-install Windows, using the license-key on the decal on the side of your desktop computer (or on the bottom of your notebook computer).
Oct 26, 2010 | Computers & Internet
My computer wont load windows a problem has been detected and windows has been shut down to prevent damage to your computer. unmountable boot volume if this is the first time you seen this stop error...
Your Operating System probably corrupted due to unexpected power failure or any other reason. You may have to setup widows again.
Before reinstallation take backup of all necessary file in a separate Hard Disk from your (C: ) Drive , existing desktop , my documents , share folder, etc. to do this you have to connect you Hard Disk with another workable PC.
After taking all necessary backup, setup Windows freshly and it is recommended to format C drive during fresh setup.
Jul 12, 2009 | Averatec Laptop Keyboard for 3200 Series
Windows has been shutdown to prevent damage to computer
try restore ur system to factory default state when u purchased it as new u can do that as follows
from ur backup OS cd
or try this
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
if the problem persists after this then i am 100% sure about hardware malfunction that is RAM problem kindly replace and check if it works or if u have two RAM chips installed try each one at a time to find the faulty one
Mar 01, 2009 | Toshiba Satellite A135-S2276 Notebook
BSOD- STOP error message
most bios updates are found on the compaq website, they need to usually uncompress to a 3.5 floppy or they are auto-installing programs u get from the website, your issue however sounds to me more like a corrupted version of windows, did you try a fresh installation with the recovery cds or master disks?
Aug 12, 2008 | Intel Motherboard
Blue screen w/msg: A promblem has been detected and windows has been shut down to prevent damage to your computer.
Youre probably going have to restore it. By doing that if there is a hardware issure it should be obvious by the installation process.
Sometimes a video card can go bad and cause this to happen. If you have another card laying around the house you might want to swap them and see if thats the case.
Jun 21, 2008 | Dell Dimension 3000 PC Desktop
I cannot reformat my pc windows xp,there's an error
If you are getting an error during installation its not good :(
Its prob either yor ram or hard drive faulty. Download memtest and test ram 1st as thats the most likely cause. Check that optimised defaults are loaded in bios also.
Jan 26, 2008 | Microsoft Windows XP Professional With...
Acer Aspire 5630 Notebook Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
