Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
My Maytag mtw5740tq0 is leaking from the...
By sheebee82 on Sep 21, 2009
My Maytag mtw5740tq0 is leaking from the bottom front after running a heavier load. What is the reason, and is this something that I can fix myself?
Comments:
Sep 21, 2009
- Gasket looks fine, after draining it I did a test run. It leaks the moment it begins to fill regardless if there is anything in it. :(
Best Solution
posted on Sep 21, 2009
Helpful)
Krazytech
Rank: Guru
Rating: 90%, 656 votes
check your gasket ... gray rubber around the door ... if there is a tear or hole.. it will need to be replaced
Comments:
Sep 21, 2009
- leak at the door or from under? also check the supply hoses for leaks..it fill tru a spot in the gasket...
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" very fast response! " - sheebee82
Solution #2
Not Rated)
TomZS
Rank: Guru
Rating: 91%, 103 votes
This is a top loading machine according to the model number correct?
You can pop open the control panel with a putty knife placed at each corner between the bottom front of the panel and the top itself to release the spring clips it hinges up and back,then you will see two clips holding the back metal panel to the cabinet,use a flat screw driver to release those open the lid and grab the cabinet,tip it toward you and off the base,then start to fill the machine keeping the back panel pulled forward and start looking for where the water is coming from.here is a copy and paste link to a video to help you remove the cabinet but your doesn't have screws in the back of the control panel.
http://www.youtube.com/watch?v=6XIsK3W_Qcg
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
No matter what size load I set my Maytag LAT8626AAE to, It only fills to the LARGE size. The switch... (More)
Answer
after drying too much steam clothes are red hot
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
