Question about Sony Grand WEGA KF60DX100 60" Rear Projection Television
Sony Grand WEGA KF60DX100 Powers on and off then 32 blinks
The TV turns itseelf off, the Standby red LEd blinks 32 times then it turns back on. It will just continue this ongoing non-stop. I tried unplugging the TV and a few other things that the Sony agent recommended however it's still the same. Any one hear of this issue? I found a guide that tells you what the number of blinks indicate however nothing mentions 32 blinks.
  • Anonymous May 05, 2008
    NOKIA 32 INCH STANBY LIGHT IS ON WHEN SWITCHED ON BUT TURNS TV OFF WHEN SELECTING PICTURE
  • Anonymous Jun 11, 2008
    i have the sony tv with 32 blinks, nobody seems to know the solution
    President:
  • 4,402 Answers
The current lamp and lamp driver part numbers and prices for the KF60DX100 are as follows:
Lamp: XL2000U, $200 (USD)
Lamp driver: 1-468-510-15, $263.16
This assumes that you have the US model.
Posted on Dec 14, 2007
Sony 3lcd wega engine tv screen turns black, power/standby button blinks 45 times, then screen goes back on. This repeats over and over again. Do you know what's wrong with my tv? Thanks.
First check your tv if it has standby power. if it has standby power please do count the number of blinks of red led. (it is on a sequence) so that we can walk through the steps and procedure to get rid of the trouble. if theres no stanby power, its probably the power supply. please do check busted fuse and replace with same ratings.
Apr 16, 2013 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Timer/standby flashes 6x
on most sony lcd projection tvs 6 red blinks is usually a defective thermal sensor. which is used for safety reasons in the tv in case in were to get too hot. the correct repair would be to replace the tempurature sensor and throughly clean all the internal fans near the lamp cartridge.
Dec 22, 2010 | Sony Grand WEGA KF60DX100 60" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv will shut off and red light will flash 3 times
If its Sony KDF-42WE655 TV that goes to standby and LED blinks 3 times then check Lamp Door that seems not fixed properly.
That happens when lamp replaced in TV.
If its different model number TV, let me know exact model number.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Mar 16, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Sony Grand WEGA KF60DX100 60" Rear Projection Television Logo
792 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
