Question about Mitsubishi WT-46809 46" Rear Projection Television
How to price a Mitsubishi WT-46809 HDTV
I am going to sell our Mitsubishi WT-46809 HDTV but I'm not sure how to price it. Any ideas?
  • sadievoth Dec 15, 2007
    We bought it in 2000. Nothing is wrong with it. Any help on pricing would be appreciated! Thanks!
I sold mine (bought late 2000) for $450 easy.
Posted on Jan 09, 2008
    President:
  • 4,402 Answers
How old? and is anything wrong?
100 - 200
Posted on Dec 14, 2007
  • Cary Farah
    Cary Farah Dec 15, 2007
    about 200 dollars is what i would pay.
Have a Mitsubishi wt-46809 tv and has a 23 shut down. ARCING is seen between the focus and the screen in the red picture tube. When the HV line for red is removed I am able to see the short as the tv...
Yep sounds like a shorted red crt for sure. You can send the tube assembly to a company called Video Display for rebuilding. They do good work and are relatively cheap. I have dealt with them often and no complaints. When they rebuilt them they replace the phosphor as well as the entire gun assembly.
Jun 16, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Wt-46809
can you please explain your problem.
Oct 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Convergence on kdp-65ws550
Good Day, s_d_duncan;
The board for this 2001 Model is no longer available. Now, if you can solder, you can repair yourself. The parts you will need are two STK 392-570 (HIC), convergence IC's, part number 270P150010.
If you can't replace yourself, please call an authorized service center to give an estimate....
Good Luck, big IRISH.
Aug 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Turns on with Power light then turns off
there are 2 fuses -24v and 24 v normally would go out because
covergence ics failled . That would be a shutting down problem cased by missing those voltages.so you would need to replace those 5A (small green fuses) , you would need some kind of soldering and unsolderin skill) and the ics are stk392 570.two also. open the set from the fron ,taking speaker grill off and then the wood board behing (4-6 screws) you the the board in the center big metal heatsink. you would need to work from the back to repace those puppies.hdtvman
Jun 07, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809 Inputs show lines across screen
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND.
Apr 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
No sound
have you tried dvd or other sources?
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809
I hooked up the DTV mode good picture but no sound ? Help please
Oct 09, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
