Question about GE Profile JS968SKSS Stainless Steel Electric Kitchen Range
Leveling glass top
Is there a way to level or adjust the glass to get it level?
  • 833 Answers
The only thing you can do is level the entire unit. Do not attempt to adjust the glass alone. The range has leveling feet all around. They unscrew to provide the adjustment you need. See your manual.
Posted on Dec 14, 2007
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
How to level Kenmore side by side model 596.50004100?
Using a bullet level, placed on top, side to side, adjust the leveling legs front and rear so that the unit places the bubble in the exact middle. Then, placing the level front to back, adjust the front only leveling legs to where the bubble in the level is only half showing in the middle. This will allow the doors to close by themselves.
Oct 09, 2014 | Kenmore Refrigerators
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
We are installing a dishwasher--have it hooked up but can't seem to get the leveling legs loose so we can adjust the height. Also, the anchoring peices of metal stick out farther than our countertop.
Hello, This dishwasher has the ability to be mounted to the cabinets on either side of the dishwasher.the mounting brackets can be moved to each side. If it must be mounted to the counter top, the mounting tabs can be bent by hand and it will break the front part of the mounting tab. This will shorten the mounting bracket. If you have granite counter tops do not attempt to drill into to the granite counter call a granite fabicator. The leveling feet are hexagon shaped at the top of the of the leveling leg. Remove the front lower toe kick panel. This will allow access to the top of the leveling legs,then use a small cresent wrench or a socket and rachet.Hope this helps.Joe Connolly
Sep 18, 2011 | Frigidaire FGHD2433K 24 in Builtin...
How do I level my GE adora side by side refrigerator
With the doors fully opened, lift up the base grill. Tilt the top of the base grill away from the refrigerator. Set the base grill aside. Attach the 1/2-inch socket to the ratchet. Inspect the arrangement of the bolts located in the area where you removed the base grill. The bolts located to the inside of the door hinges are the leveling bolts. The top bolts adjust the back of the refrigerator, and the bottom bolts adjust the refrigerator's front edge. Adjust the leveling bolts as necessary with the 1/2-inch socket attached to the ratchet. Turn the bolts clockwise to raise the corner or counter-clockwise to lower the corner. If you notice the head of the leveling bolt pushing away from the face of the refrigerator as you loosen the bolt, re-tighten the bolt until the head pulls back flush. Switch to the other corresponding bolt to adjust the level of that side of the refrigerator.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting
Sep 07, 2011 | GE Adora (DSF25KGTBG) Side by Side...
Refrigoator door does not vacuum seal tight like it used to when new. Door barely stays closed on gasket.
What I hears sounds as if the refrigerator needs re-leveling. Here are some basic things to do as in this video. Every refrigerator is not always the same but the idea is to cause the doors to shut inward if you should be standing in the front and let both doors loose from your hands the doors should shut inward and firmly if not over adjusted in the final steps. Your model is a nice large model! Here is what one user manual mentioned below.
NOTE: Custom or full-overlay door panels must be installed
before leveling.
1. Open the door and place the level on top of the refrigerator
frame as shown. Check to see whether the refrigerator is level
from left to right.
2. Use the leveling bolts to adjust the leveling legs until the
refrigerator is level from left to right.
3. Place the level(s) on shelf or shelves. Check to see whether
the refrigerator is level from front to back.
4. Use the leveling bolts to adjust the leveling legs until the
5. Be sure that all four leveling legs contact the floor and
support the full weight of the refrigerator.
6. Make final check to ensure the refrigerator is level.
Adjust Door Swing
1. Check that the refrigerator door can open freely. If the door
opens too wide or you are installing full-overlay custom
panels using a Trimless Trim Kit, you should adjust the door
2. Remove the door stop screw from the bottom hinge.
3. Hold the door open to a position that is less than 90°.
4. Replace the door stop screw in the bottom hinge and tighten.
NOTE: If you are using full-overlay custom panels with the
Trimless Trim Kit, the door stop should be replaced in either
the 90° or 110° position. See "Handle and Door Clearances
for Custom Panel Series."
Install Side Panel
If the built-in area depth is 25" (63.5 cm) or more, the side panels
can be installed inside the side trim or attached to the outside of
the side trim.
IMPORTANT: Thermador is not responsible for the removal or
addition of molding or decorative panels that would not allow
access to the refrigerator for service.
1. For the inside side trim piece, slide the front edge of the
routed side panel into the trim piece.
2. Nail the rear edge of the panel to the support board.
A. Level to check left to right leveling
B. Level to check front to back leveling
A. Rear leveling bolt
B. Front leveling bolt
A. Door Stop in 130° position
B. 110° position
C. 90° position
Thanks, Sea Breeze
How To Level Refrigerator Doors
Apr 21, 2011 | Thermador KBUIT4870A
Need to get refrigerator levelled. How do I do it
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Jan 16, 2011 | Refrigerators
My range top is not excatly level how do you level a glass top range?
Most ranges have leveling legs. Remove the storage drawer and look to see if the legs have threads. Then twist a leg clockwise to raise one corner or counterclockwise to lower it. (It could be reversed - it's been awhile since I leveled a stove.) Adjust as needed to get the stove level front to back and side to side.
BTW: the parts diagram for the 95002 chassis is here: .
I hope this helps.
Jan 12, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
Leveling my machine how do you calibrate to level it
Place a level on the top of the machine and move down to the feet.The levelers have a lock on them which you must turn counter-clockwise to unlock. Now, adjust the feet until it is level. Check front to back and side to side. After leveling, run on spin with load and check feet. If one foot is not solid on the floor, adjust it down until it is. Lock the locks and you are level.
Jan 24, 2010 | LG WM-2277HW Front Load Washer
Leveling the machine
adjust the bottom leveling legs on the machine
May 06, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kitchen Ranges Logo
141 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
