Also, is it new? Same thing happened with mine when I first bought it maybe 72 hours of purchase. Took it to the Apple store and it was deemed defective. If it isn't new, then you will have to pay for them to look at it, so consider your options. If you've had it for more than 2 years, then you can go with cssidy's 2 suggestion and buy a new 3G for $99 bucks. It would probably be the cheapest option
Did it get wet? If not you need a new logic board. if it DID get wet, try to open it and clean it out. There is a step by step guide too that explains a little bit at eachsteps what you have to do : iPhone screen repair. You can buy the touch screens online too. There are also iphone repair companies that do it for you.
No fix for this you can take it to apple they charge $220 to refurbish the phone your better of buying a new 3g for $99 but if you cant apple will fix it for you and send you a loaner the repair time is usually 3 days
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
