Question about Intel PRO/Wireless 2200BG 802.11g/b
Wireless switch cannot turn on the intel 2200 agb wireless adapter for my laptop
Cannot turn on the wireless button on intel wireless 2945 wi-fi adapter with wistron eletronic button switch, any idea it make the wistron button work on the intel? I loaded the intel driver and the laptop is reading with no problem, but just cannot turn oon the Wistron wi-fi switch. I have a Seanote MS2137 notebook with Intel Centrino 1.4GHz system Pentium M
    Problem Solver:
  • 8 Answers
*Assuming that the computer is a windows XP Operated.
Click on start => run => Services = Ok.
On the services window => check the status of the wireless zero Configuration => try switching it 'on' or switch it off and then switch it 'on'. If that does not resolve the issue then it could be hardware failure.
Posted on Dec 23, 2007
Dell laptop not connecting to wireless network
ok
1. double check wireless switch
2. and double check wireless driver
3. my computer right click and select the manage and select the device manager and select the network adapters and select the wireless device right click and select device automatically update and next update your drivers.
4. now check the wireless.
Apr 27, 2014 | Computers & Internet
I have a gate way laptop with Intel® PRO/Wireless 802.11g integrated wireless 10/100/1000 Mbps integrated Ethernet LAN card, i cannot connect to my wi-fi network, is it possible that the wi-fi card is...
Wi-Fi card can be considered broken only if its not able to scan for any available networks. Also, do check in the device manager of the computer. Check for the device status of this wireless adapter there. If its properly installed, etc., it should say, "This device is working properly". There is also a fix for other error messages. Regarding hardware breakage, we cannot come to a conclusion so easily as we have all these things to check. The case may be little complicated as its an in-built wireless card. We cannot even remove it and try on a different computer.
Mar 17, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
I dont know how to turn my wi-fi on on this labtop
look around ur laptop, there should be a button key or a switch 2 turn it on. if look on the bottom right on ur taskbar, there might be an icon for ur connections e.g. bluetooth, wlan, wi-fi etc. see if u can switch it on from there. if u still can't do it take ur laptop 2 a pc world center and they might be able to help u. i hope dis helped =)
Aug 26, 2009 | Everex StepNote NC1502 Notebook
How do i set up this comp. to show wireless connections
Install wi fi network adapter driver.
Turn on wi fi switch it is on laptop you can find it easily.
Then you can see your wi fi network in my network places.
Jul 31, 2009 | Dell Inspiron 2200 Notebook
Laptop wont connect to wireless how do i turn it on?
check your wi fi netwrok drivers are installed and working fine.
Also check your wi fi switch on laptop is turn on.
Also check your wi fi network adapter is enable.
Jul 22, 2009 | Computers & Internet
Wi fi driver
Hello, most common Wi Fi- Adapter for your notebook is:
Intels Pro-Wireless-2200BG
download driver here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637
Apr 30, 2009 | Dell Latitude D610 Laptop Computer -...
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
How to turn on wireless on Acer Aspire 4520 laptop
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Sep 04, 2008 | Computers & Internet
Wireless adapter
You can use a USB wireless adapter.
Mar 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Intel PRO/Wireless 2200BG 802.11g/b Logo
1,356 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
