Question about Philips 150S3 (Black) 15 in. Flat Panel LCD Monitor
My Viewsonic monitor!
Hey...I bought a new viewsonic monitor...the problem is that all the red places appears black...I dont think its an issue wid the video card...any soln???please reply quick
myob247
  • 1342 Answers
SOURCE: I have a monitor that was given to me.
OSD Lock Settings
You have the option of using the OSD Lock feature to prevent current image
adjustments from being changed.
• OSD Lock: Press and hold [1] and [J]
for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and [J]
again for 10 seconds.
Posted on May 03, 2008
RCtech
  • 55 Answers
SOURCE: Issue with my 17" Viewsonic VA1716w LCD monitor
If all the buttons on the front don't work I would beleive it was a cable that is not connected correctly. I've seen things like this happen on otherwise perfectly good equipment. It's probably an easy fix however, monitors have enough power to KILL YOU (dead not a little bit very dead) if your not sure what your doing find someone who is most things I encourage you to open up and play with but not monitors. (did I mention you could die)
Be careful
Rob
Posted on Dec 10, 2008
ginko
  • 19396 Answers
SOURCE: VX922 monitor, blank screen, blinking power light
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact Viewsonic to find out a Viewsonic service point.
See:ViewSonic - Support & Service
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Posted on Mar 06, 2009
SOURCE: resolution problem of viewsonic VG2021m as the second monitor of thinkpad t61p
Go into the NVidia control panel, create a custom resolution (for the ViewSonic VG2021m, you want 1400x1050, 60Hz), and test it.  When the test asks you if it looks ok and you click "yes", it *still* is not activated-- it is simply added as one of the resolutions available for the monitor, and goes back to the same setting you had before... so it looks like it didn't work.  But then, if you go under "Change resolution", you'll see your new setting is available there.  Choose it, and you are good.
It's working for me, on my T61.
Dan
Posted on Jun 19, 2009
bammbammfran
  • 159 Answers
SOURCE: viewsonic vx924 power/inverter board
See ebay item 390074135923
http://cgi.ebay.com/2-Inverter-transistor-viewsonic-VX910-VX924-DK-QB-QO-QA_W0QQitemZ390074135923
Fran
Posted on Jul 27, 2009
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
Hey I have a viewsonic VX2245WM and my problem is that when I turn my computer on the monitor light goes red-ish like a red light that is starting to fade away and the screen is completely black like its...
Almost the same chassis as VX2235.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | ViewSonic VX2245WM LCD Monitor
Just bought a new viewsonic vga1703wb monitor. Plugged it in and turned computer on. Microsoft display comes up and then screen goes black and says 'no signal'. Can you help?
shut down the computer start it again press F8 immediatly and keep pressing untill menu appears highlight on "enable VGA mode" and press enter, your problem will be solved
Apr 11, 2010 | ViewSonic VA1703wb Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Jun 29, 2009 | ViewSonic VX910 19" LCD Monitor
Bought a new viewsonic moniter,where do plug the speakers into
I brought pc with ViewSonic VA1912wb 19" LCD it have in built speakers or not how i connect get suond with out externals speakers
Jun 28, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
ViewSonic monitor color red is orange
hi there, try replacing the video cable, you may have a one broken video cable, sometimes the pin is broke out. ty
Dec 26, 2007 | Acer AL1916W 19" LCD Monitor
Philips 150S3 (Black) 15 in. Flat Panel LCD Monitor Logo
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
