Question about GE 28021EE2 Phone
Incoming Ringtone. Hi iam using the GE 5.8Ghz 28021EE2 phone. i could not hear the ring tone , when somebody call me. i set the settings to default and gave the area code. even i set the ring volume to high but still the same problem.. it was working fine before. but when i disconnected it and set it to another DSL connection , it rings nomore. Please help me to solve this issue. BR, SH
  • 201 Answers
SOURCE: Intermittent Ring
Sounds like you are having a problem with the generated ring signal from the cable phone service. An old fashioned Ma-Bell ring signal is a pure 90v AC 30hz pulse. Your cable box needs to generate a simulated ring signal from a DC power supply. I have seen many examples of this fake ring signal not cooperating with specific phones. It's a long shot but your phones MAY have a setting for the phone line(s) (A/B) (Analog/Digital) etc... of you can find a setting dealing with the "CO line", "phone line" etc.. try changing it. I am surprised another phone in the loop will help the ring signal at all. I would think it could only weaken it. Try plugging your phone in question directly into the cable line instead of having the whole house connected. The ring signal may be trying to power too many devices or weakened by something connected to the network. Other than that, you are dealing with the ring signal generated by the equipment and I'm sure it's not adjustable.
Posted on Jul 07, 2007
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
SOURCE: GE cordless dect 6.0-do not disturb
According to the instructions, you only need to press the "do not disturb" button again. The button is on the base (not the phone).
Posted on Mar 21, 2008
SOURCE: My phone works, but it doesn't ring!
my phone works but dont ring
Posted on Nov 29, 2008
SOURCE: GE photo phone - CID not working in India
I doubt it will work, as there are differences between the codes that US phones expect for caller ID and what India is sending....
Sorry, but that wont work.
Posted on Jan 03, 2009
SOURCE: I have GE 5.8 GHz model 28021EE2-A with no user guide
If you don't have users guide then just bech maro that product........
Posted on Jan 25, 2009
0 characters
1 Points
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Phones
My ringtone and vibrate alert is not working when i have a incoming call
Open menu and select tones see if the ringer settings are in place, if not set the tone and volume and set ******** to on.
If this does not bring in the ringing,then opne menu, setttings, restore to factory settings-- type 12345.
the set will go to factory settings.
If not remove batter and reinsert after about 10 minutes.If there is no result then the phone hardware can be faulty.
Sep 02, 2010 | Nokia Phones
How do I change the ringtone (incoming call) on the phone set?
You can change the incomming ringing for your set by pressing feature *6 , press the next key to select the ring type and ok to store the new ring tone.
Feb 22, 2010 | NorStar T7316E Corded Phone
Just got this used phone for to change the ringtone It's a very annoying one now.
usually this is done one of two ways
if the phone has a menu button
press it once then use the arrow keys until you see "ring" or "ring tone" in the display
then use the arrow keys again and you should hear different ring tones. when you find the one you like press the menu button to lock it in
if the phone has a program button and no menu button
keep pressing the program button until you see "ring tone" in the display.then use the arrow keys until you hear the ring tone you like. then press the program button several times until you exit the programming mode.
you can follow the above steps to set the ringer volume also
Jul 15, 2009 | Uniden Cordless Phone
Jan 25, 2009 | Uniden Cordless Phone
Samsung u600 ringtone!
its gonna work after when u **** ur sister
Mar 21, 2008 | Phones
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Tone delay
Here is a link to the operating manual which may help :
You could try disconnecting the phone by unplugging it for abaout 10 seconds, then all phone settings would revert to manufacturers default settings.
Jan 21, 2008 | Panasonic KX-T7730 Corded Phone
Will not ring
Had the same trouble reset the phone to defaults and do not register handset. Enter the area code and program the ringer volume. Use the PROG (MUTE PROG) key & the CALLERID-VOLUME buttons to make selections in the menu on the screen. to save the setting press the PROG key.
Jan 31, 2007 | GE 28021EE2 Phone
GE 28021EE2 Phone Logo
16 people viewed this question
Top GE Phones Experts
Are you a GE Phone Expert? Answer questions, earn points and help others
