Hard drive problem
Every 4/5 days my laptop fails to boot and I get message "no operating system found"----my drive is only a few months old. However, I have found that if I take out the drive and replace it there will be no problem for a week or ten days. Thus I suspect the problem has something to do with a build up of static. How can I prevent this and save all the hassle?
Dr John Wright
  • Anonymous Dec 14, 2007
    Please describe the specifics of your problem below. We'll add
    your post as a comment to autolycus's Hard drive problem problem, and notify you when a new solution is offered
  • Anonymous May 25, 2008
Posted on Dec 14, 2007
When statring my computer hp presario cq61 a message appeared "no bootable device found. then i made the hard disk check and it showed "no hard disk exists" What can i do?
Here are a few possibilities:
1. A huge possibility is that your hard drive has failed. This usually happens to computers 4 years old or longer. Unfortunately, it would be pretty costly to recover any data on a failed hard drive. You will have to replace the old hard drive with a new, compatible hard drive and install a fresh operating system on it. To do this, you need to consult someone who is somewhat familiar with computer troubleshooting or visit a store such as BestBuy for help.
2. The hard drive's cable is loose or disconnected (This usually happens when the hard drive was recently tampered with)
Apr 11, 2011 | Computers & Internet
I had just purchased a Dell Inspiron N4010 laptop 2 months ago. It work well until few days ago. It hangs whilst at the screen 'starting windows'. After that it showed the message of 'check cable...
hello miss sally, hi, the operating system error may be caused by a faulty hard disk or hard disk connection cable, and the hanging thing is caused by a faulty memory module, so check then out first, swap a new memory module, and for your hard drive, take it out from your laptop and use a PC to test the drive (applicable only if your hard drive is sata.)
Nov 19, 2010 | Dell Computers & Internet
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
"Operating System not found" message
The operating system not found using means just that the OS isn't correctly installed or the hard drive isn't being detected by BIOS. You may want to try reseating the hard drive in the laptop.
Hope this helps. Please remember to rate this information.
Thanks
Dec 09, 2008 | Computers & Internet
Operating system
This will be either an operating system glitch of a failed hard drive. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive will not format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Sep 03, 2008 | Sony VAIO VGN-S460 Notebook
Not booting up
Many times this error message indicates a hard drive failure. You will need an operating system disc in order to fix this or determine if the hard drive has failed. There is no other way around it unless you want to take it to a shop for repair. I wouldn't recommend Bestbuy, their very expensive. At Bestbuy you're looking at around $200 just for the system reload, this doesn't include a new hard drive if it has failed. If you decide to do this yourself, again, you will need an operating system disc, then do a system repair. If the repair doesn't take, then reformat the hard drive and install a fresh operating system. If you have any problems during or after the format or reload, then the hard drive has failed and will need replaced.
Jul 24, 2008 | Acer Aspire 5500 5570-2609 Laptop
Vaio error message
This generally indicates a hard drive failure, but occasionally it's just an operating system glitch. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a fresh operating system. If you have any problems during or after the format or install, then the hard drive has failed and will need replaced.
Jul 24, 2008 | Sony VAIO GRX550 Notebook
Os not found
Operating system not found indicates that the system is not seeing a bootable device. Possible causes are:
1. Hard drive not detected due to loose connection. Reseat the HDD.
2. Hard Drive is failing/Failed. Replace HDD
3. System has a floppy drive and a diskette in the drive, remove diskette, reboot
4. Hard drive not in boot sequence. Reset BIOS to defaults
Jun 22, 2008 | Acer Aspire 5050-3242 Notebook
Laptop wont boot
Every time I have had this problem, it was either the drive or the drive being reconogized in the BIOS, or a glitch in the operating system. I would go into Setup at the boot up and see if the BIOS is reconogizing the drive. If it does, then I would use the operating system installation CD but not do a install but use the repair feature. In the repair function run "chkdsk /r" many time this will cure a problem. BPCS
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
195 people viewed this question
Alun Cox
David Payne
David Payne
