Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Keeps going back to 2H
Hi we had the keyboard panel replaced 1 month ago. When I turned it on this morning it keeps going to the 2 hour delay cycle but it sounds like it is running and the minutes are moving down but nothing is cleaning inside the dishwasher
    Problem Solver:
  • 14 Answers
Have you tried cleaning out the pressure chamber and transfer pipe??
Posted on Jan 17, 2008
TV turning off my itself after a couple minutes.Was told to replace the main board.Replaced the main board and tv played perfect for 1 month.Now it is cutting off my itself again.Whats going on?
Hi Johnny,
Please take out the main board, keep it immersed in mild liquid detergent solution for some hours, rub it thoroughly with a tooth brush, wash it with clean warm water, dry it thoroughly with hair drier and fit it back. Hope it works. It has done the trick for me several times.
Good luck.
Jan 10, 2016 | Dynex Televison & Video
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Jan 04, 2011 | Dishwashers
Stays on 2H when turning on
Hi welcome to Fixya. You're right what you're describing is not delay start, but rather a problem with one of the heating component's and most likely the heater relay on the electronic control. The wash cycle has exceeded two hours without a temperature increase of the water and therefore the control "thinks" something is wrong. Whether there is or isn't remains to be seen. Likely if you let the unit operate from that point of displaying "2H" it will run and run for several hours and not heat the water. You can confirm this by pulling out the control and visually inspecting the printed circuit side of the control. Look for a burnt solder on the opposite side of the largest relay ( black or orange retangular box ). That will confirm the heater relay is faulty and the control either needs to be replaced or repaired if you are capable of resoldering the board. Let me know what you find and I'll try and assist you further if you require any. Thanks for visiting "fixya" today and good luck moving forward. macmarkus :)
Jun 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Aug 16, 2009 | Maytag MDC4650AW Built-in Dishwasher
Can not reset the ''delay cycle'' timer
I would call that service company back and ask for your money back first of all if he didn't fix the problem. That code probably means a failed circuit board.
Mar 14, 2009 | Dishwashers
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
May 27, 2008 | Bosch 24 in. SHU6802UC / SHU6806UC...
Prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Jun 24, 2007 | Bosch SHU5307UC Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
89 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
