Question about Baby Trend Expedition LE Jogger
Hand Brake not functional
How do I adjust the hand brake? I never received a manual with my jogging stroller and I suspect that I put it together wrong.
  • 17 Answers
I checked the Baby Trend website and did not see a listing for an Expedition LE Jogger stroller. I did, however, find the Expedition LX as well as several other Expedition joggers with numbers at the end.
Here are instructions to the LX Jogger.
Here are instruction for the Standard Expedition Jogger.
Here are instructions for another version of the Expedition jogger, as well.
You should be able to use one of those to best match your stroller and make sure you have correctly assembled your stroller. Should you need further assistance, they have a customer service line at (800) 328-7363 open from 8:00am to 4:30 pm, pacific coast time.
Posted on Dec 18, 2007
How do you adjust the hand brake on a 2001 Mitsubishi diamante
1. Adjust the rear drum shoes for minimal clearance. Note that the linings may need replacing.
2. If necessary (and may not be) replace the two hand brake cables. Cables can rust solid and jam, but rarely break.
3. Remove the center tunnel cover between the front seats. Adjust the cables so the hand brake handle has minimal upward movement.
4. Put it all back together.
Nov 04, 2017 | 2001 Mitsubishi Diamante
I need a schematic for the parking brake assembly on a 1991 mazda mx5 (rear discs). The parking brake stopped working and only barely gripped even after adjusting the hand brake adjuster to 5 clicks. I...
Try to get a copy of parts schematic from the Mazda dealer for the rear brake parts . Check on line to see if that diagram is available on free download. Check the aftermarket brake spares to see if you can get a copy. Or buy a workshop manual for your car.from a auto spares shop.
Oct 14, 2013 | Cars & Trucks
How does the brake work?
there have been countless accidents where unattended strollers have run away causing ***** to the child
the idea that you have is to prevent that from happening if you fail to apply the wheel brake
to do anything to prevent ti from working as designed will result in legal charges being place on you in the event of a accident involving injury to the child
it is not intended as an incinvience to you but to ensure the child's safety when you are inattentive
May 17, 2017 | Schwinn 13-SC906A Free Wheeler - Red/Black...
Quinny buzz brakes arent working
Hi
The Quinny Buzz brakes can be adjusted (and should be periodically as part of the ongoing maintenance of the product to ensure good performance)
The brakes may require periodic adjustment. To do this, use two 8mm spanners to unlock the lock nut from the long barrel nut. Adjust the brake cable and retighten the lock nut. Test the brakes to ensure a positive engagement and disengagement after adjustment.
Sep 19, 2012 | Quinny BUZZ 3 Capri Stroller
My insignia hand brake has locked on how do i release rear offside only
you need to take off the rear wheel and there is a hand brake hole in the drum on the disc. you locate the hole with the adjuster.. make sure the hand brake is not on. the leaver for the hand brake take the cable off if the brake is locked the leave will let you take it off. then get a peace of wood and put it on the leaver and hit it back with hammer on the wood not the leaver. then take the screw out for the locator of the disc. and hit the disc with rubber or plastic hammer going round the disc. not to hard just to get it to move when of find out why the hand brake is locked in the first place. ( prob be the shoe's pins ) change the parts. while parts off give good clean and put some copper grease on the parts that move. huck back up the cable and check disc drum part for damage. screw the adjuster back down and refit. when disc back on adjust the brake with the hole lined up and move back and forth until the brake is locked then turn back one point on the adjuster check the disc turns and then use the hand brake. if still an bit hard to move after hand brake off nock the adjuster back down one more and test again. if all well put wheel back on.
Jun 04, 2012 | 2003 Vauxhall Vectra
I got this stroller as a gift w/ no manual. I took it apart 2 wash it & now cannt get it back together. Not sure if Im missing parts cause I cannt get it 2 stand up. Please help....
  • Lightweight steel frame - Lightweight for storage and easy to push
  • 5-point safety harness - Extra security and comfort for baby
  • Retractable canopy - Provides extra sun protection
  • 16" Quick release wheels - For a smooth ride and compact storage
  • Bicycle style hand brake - Easy and smooth braking
  • Recline seat - Additional comfort for baby
  • Bi-weave fabric - For durability and fashion
  • Independent rear suspension - Reduces impact on uneven terrain
  • High top canopy - Increases internal head room
  • Underseat storage basket - Additional storage space
  • Parent console - Great for beverages and other items
  • Age limit- 6 months of age or older
How To Buy: %howtobuy% cond_%howtobuy%--> clear.gif clear.gif cond_%description%--> MODEL NUMBER: 11-KS185 BRAND: InSTEP COLOR: Sage/Blue MAX WEIGHT LIMIT: 50.00 lbsBAR CODE: %product_barcode% cond_%product_barcode%--> CARTON CUBE: 3.69 CARTON DIMENSIONS: 33.5CARTON WEIGHT: %product_cartonweight% cond_%product_cartonweight%--> FOLDED DIMENSIONS: 35 ASSEMBLED DIMENSIONS: 50 ASSEMBLED WEIGHT: 26.00 lbs Select a Frame Size: %frame_size_options% cond_%framesize%--> clear.gifAccessories: %product_accessories% cond_%product_accessories%--> clear.gif clear.gif 5K Single Premium Jogging Stroller manual.pdf
Hit the link above, this is a discontinueds item. You must have a pdf reader to view, but try the link first before you go looking for a pdf reader.
Good Luck
Apr 25, 2012 | InSTEP 5K Single Premium KS185 Jogger
How do I adjust the handbrake on my ' 87 Toyota Camry?
Hand brake cable comes all the way to the rear and the linkages can be adjusted on either side.
Jul 22, 2011 | 1987 Toyota Camry
Bmw 320 hand brake not functioning properly
either the hand brake needs to be adjusted or the rear brake shoes , which are inside the rear discs are worn not allowing the hand brake to work
Mar 22, 2009 | 1997 BMW 5 Series
Hand brake adjustment for schwinn point beach crusier
The brake that you are adjusting go to that wheel. On that wheel you will see a brake pad on each side of the wheel. To adjust tighter you squeese these two brake pads together, you will see a wire, there will be a nut that they wire goes through, loosen the nut and squeese brake pads together, then tighten nut back up. your hand brake will now be adjusted.
Feb 24, 2009 | Cycling
Brakes Mazda Famillia 1989
Id be inclined to adjust the rear brake shoes How high do you have to lift the hand brake lever?Some service centres/mechanics adjust the hand brake cable and not the shoes as they should because its easier and quicker Its a short cut !!
Oct 22, 2008 | 1989 Mazda 323
Baby Trend Expedition LE Jogger Logo
490 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
