Question about HP Pavilion zd8000 Notebook
Dell laptop wont run with power cord and wont charge battery
Wall power outlet good, power cord connection to both wall outlet and into laptop good. Laptop will not run on powercord power, just wants to run on battery. Because battery not being charged; is dying a slow death. What causes this?
  • 69 Answers
Could be the A/C connector on the mother board this would have to be replaced by a TECH if your cord is good and you have voltage coming out of the end of the cord that plugs in to the laptop then your A/C connector on the mother bord is bad and its a common problem this happens with use, if the laptop is new then return it if not it could cost $120.00 to fix. GOOD LUCK
Posted on Sep 21, 2009
My new battery is not working with my Sony vaio laptop
What do you mean the new batter is not working? Does the computer turn on with the Power Cord? If not, the power cord is bad and cannot charge the battery. I have seen times when new batteries are defective. The new battery does not come charged so you have to plug in the power cord and let it charge overnight.
Apr 06, 2012 | Sony Computers & Internet
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
I plugged it up to my PC over night to charge and it wont charge
I would check to make sure that the power cord is plugged into the wall and is making good connection. Use a lamp to test the outlet and make sure it is working. If you eliminate the outlet as a cause of problem, check to make sure that the other end of the cord is plugged solidly into the transformer (the plastic "brick"). If it is, check to see if the transformer gets really hot over time. If it does, it is a problem with the transformer and you should replace it. Check the connection where the power cord plugs into the laptop. It should be plugged in all the way and shouldn't be loose. If you are getting good power to your computer (normally there is an indicator light on the laptop somewhere that tells you when its plugged in), and it just will not hold a charge, It may be time for a new battery. You can contact your computer's manufacturer for replacement batteries and chargers.
Mar 05, 2011 | Computers & Internet
My laptop wont charge at all there is no power to it at all
it sounds like your battery is the problem..
Do the following:
  1. disconnect power to the laptop from the wall (110v)
  2. remove the laptop battery from the laptop
  3. re-connect the external power (wall outlet 110v) back to the laptop
if the laptop powers on, now you know it was the battery.
if not, you'll have to take it into a service store to determine if one of the below is faulty:
  • motherboard
  • power cord
Feb 24, 2011 | Computers & Internet
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Dell Inspiron 1000 won't turn on. It is always
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Jan 03, 2010 | Dell Inspiron 1000 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
HP Pavilion zd8000 Notebook Logo
170 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
