Question about Legacy Audio Blue Diamond LA1880 Car Audio Amplifier
Legacy amp in protect mode
Hya i have a leagcy la 798 wich a live wire hit the speaker out put then wnt into protect made a chip had blown so i replaced it but still in proctect plz can sum 1 help !!!!!!!!!!
  • 3 more comments
  • biggy19 Dec 15, 2007
    ummmmm not sure mate i think its caleed a heat shrink chip but not 2 sore
    yes will do thanks alot 4 ur help
  • biggy19 Dec 18, 2007
    1. heres the two chips i replaced that were burnt out but still in protect mode
    • this is the whole and the red 1 can be used for parts i hope
    thanks alot mate realy helpfull ill let u no how it gos
  • 631 Answers
What was the part number on the transistor you replaced?
Posted on Dec 15, 2007
  • Perry Babin Dec 15, 2007
    Can you post a photo?
  • Perry Babin Dec 18, 2007
    It appears that there were four of the IRFZ44 power supply transistors (or whatever transistor they used in this amp). If that's the case, you need to replace all 4 instead of only two (for better reliability).
    The amp is probably going into protect because one or more of the output transistors has failed. Measure the resistance between legs 2 and 3 of each of the individual output transistors. The outputs are the 4 larger transistors clamped to the heatsink on the other end of the amp. If you find any that read near 0 ohms between legs 2 and 3, it's probably defective and needs to be removed from the board to be checked. Mark their locations before removing them if you remove more than one at a time.
    You should also read through this web page. It will help cover the basics.
Kenwood kac-6295 shuts off then turns back on at high volumes
Did you wire the speakers in series or parallel? 4 ohm speakers in parallel actually come out to equal 2 ohms wich most amps would see as a short causing protection issues. 4 ohm speakers in series equals 8 ohms which should be fine for your amp. been there : expert-tech / SAM
Mar 27, 2012 | Car Audio & Video
I have a Legacy Predator 2000 watt amp with 2 12'' Kicker speakers. It has been in my car for about a year now, and it recently just stopped working. I have the green light to the amp, im not sure about...
If you have checked your ground, live, remote and RCA's, The problem may lie with your kicker speakers.
There may be a loose wire connection on the speaker terminals (hense no sound).
Check the terminals at the speaker (+) and (-) then check the speaker wires to your amp inputs.
Usually if there is a fault with any wires linked to your amp, the amp goes into protect mode.
If your amp is not going into protect mode, try linking a different speaker to each terminal on your amp (left) then (right). If you get sound through a different speaker, more than likey your speaker wire to your kickers has came loose (due to vibrations) or there is a break in your speaker wire.
Hope this helps. If any more info is needed I'd be happy to help more. Please rate if helpful
Mar 18, 2011 | Car Audio & Video
I couldn't able to switch on my sony str db930 .when it was use it say me protecter.
Check all of your speaker connections... usually the PROTECT cuts in when speaker wires get crossed or you have blown a speaker.
this PROTECT message also shows if the amp chip(s) have blown in the unit
Sep 01, 2010 | Sony STR-DB930 Receiver
Amp in power protect
Protection Circuit is bad. It needs to be serviced. If all speaker wires are disconnected and it's still in protection, it's got a problem. Hope this helps
Aug 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
My amp automatically goes into protect mode
There are 4 reasons an amplifier tries to protect itself.
Overheating - thermal shutdown.
Over Impedence - The subwoofers installed are not configured into a load the amplifier can handle.
Output is grounded - a positive wire strand may be touching the ground terminal - a wire may be shorted, or a speaker voicecoil is blown.
Intennal problem - Output on amplifier blown, or some other component has failed.
Check your wiring to the amplifier again - if all is good - disconnect the speakers and try to power on. If the amplifier turns on normally - test the speakers for blown coils.
If the amplifier still goes into protect mode - the problem is internal and needs professional repair.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | AudioBahn A2301 2-Channel Class A/B Mosfet...
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Amp not working
well it sound like you most likely damaged the audio output transistors. take a multimeter & test the outputs. remember they work in pairs so if you find 1 replace the one next to it also. in the amp you will find many transistors, the o/p transistors are the bigger ones.the transistors will be stamped with a part number, typically add "2S" in front if you try to find the parts yourself. good luck.
Dec 19, 2006 | Legacy LA498 Car Audio Amplifier
Amp shutting off going into protection mode
Check this out:
Aug 14, 2006 | Legacy Audio American Legacy II LA690 Car...
Legacy Audio Blue Diamond LA1880 Car Audio Amplifier Logo
108 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
