Question about Lite On Lite-On LVW-5045 DVD Recorder with 160GB Hard Driver :
Lite On USB TV Tuner
Hi, I have dowloaded the software and the Savvy TV screen luanches, however, all the buttons are "greyed out" and in setting I the tv tuner bit does not appear so I cannot view the TV...?
Any ideas anyone
0 characters
1 Points
How do I record future programs using duel mode on tv2
To whom it may concern,
When you set an event to record you will be prompted as to whether or not you'd like it to record on tuner one or two. Simply select tuner two.
Best of luck
Dish guy
Feb 24, 2015 | DISH Network TV Receivers & DVRs
I hit the source button, and now my screen is blank with hdm1 in corner
No problem. Keep pushing the "source" button until it goes back to "tuner". You should see "component", "s-video",etc.. also. These are the various "sources" that can be plugged into your TV. To watch regualr TV, you need "tuner"...
Good Luck.
Apr 21, 2014 | Emerson TV Receivers & DVRs
Hi, I would be happy to assist you with your question. Prime Time Any Time is a feature of the Hopper that allows your local channels to be viewed using one tuner. It also allows for the recording of all four major networks ABC, CBS, NBC, & FOX during prime time hours using one tuner. If one TV is set to a local channel than you can press the Red Hot Key on any DISH Remote and it will display the TV Viewing Screen and all the locals will be listed. You can scroll to and select any of the locals listed and it will play on that TV. If you are still having issues and need additional assistance, please feel free to PM DISH directly on facebook here: Thank you!
Mary Catherine Brady
Team Lead- Social Media
Sunday-Wednesday 2:45pm-11:15pm, Thursday 1:30pm-10:00pm (MST)
Feb 01, 2013 | DISH Network Hopper Whole-Home HD DVR
Fix split screen
There is no split screen option in a Comcast box. If your TV has a duel tuner you can get 2 boxes one for each tuner and still use that option in your TV. If you have a split screen on your TV and one is snow then you will need use your TV remote it came with to exit out of it.
Jan 25, 2013 | Comcast XFINITY
Can i use the USB port on my sagum freeview reciever to download programmes to my PC?
This appears to be a television tuner with accompanying recording software. You can watch TV and record what you watch. You cannot "download from the Internet" using this device, if that is what you mean.
Jan 09, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Cannot swtich on the tv
I think you mean ' switch ' and ' only the red light ' ( power ) comes on.
It could be an internal trip on your tv set that needs looking at by a tv engineer ( normally parts required ) or if you have a tv with a ' factory settings button ' on it ( normally on the side or top if it's a flat screen tv ) press and hold for 10 seconds then the intial ' tv setup ' will appear on the screen ; after that, just follow the guide.
Hope this helps.
Jul 24, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips TV Receivers & DVRs
Motorola Dual Tuner PVR - DCT 6412-III --- HELP
The information provided shows that tuner 2 isn't working at all on at least the selected channel. This could be a problem on just some channels with this tuner or possibly all channels. You can verify this by hitting the "SWAP" button on the remote to switch tuners while viewing a live program on a problem channel. If you choose the same channel for each tuner, I expect you will see program on one and "one moment please" or freezing or pixelation on the other. The confusion about recording comes about because of how the DCT6412 chooses which tuner to use for recording versus viewing. If you activate record on a channel you are watching, it will use that tuner. If you see it, it will record. For future or series recordings though it will automatically choose to use the alternate tuner so that it won't have to change your channel selection. Since there is no input signal detected on the other tuner, it will actually record but there will be nothing to see on play back. What causes this? It is probably that tuner 2 has failed. There is a slim chance that your cable signal coming in is either too strong or too weak but this is unlikely since the DCT6412 splits and then amplifies the cable input signal before distributing essentially equal signals to both tuners (the plug on coax adapter on the back feeds the cable signal to an AGC amplifier within the DCT6412 and then splits and distributes that output to both tuner inputs). You could check the OOB AGC level as described here but I think your problem is more likely that tuner 2 has gone bad. JM Belleville Ontario
Dec 12, 2008 | Arris DCT6200 DTV Receiver
The writing on the screen is stretched beyond the width of the screen and I lose script on either side - I have checked the fine tuner on the remote but it doesn't seem to have the ability to fix the...
if you have a wide flatscreen tv it could be that the picture size is in the wrong mode. under the mode button on your tv remote should be two buttons labeled wide and zoom. try pushing these buttons to adjust the tv screen size.
May 02, 2008 | TV Receivers & DVRs
Dell TV hard time turning on
Jan 03, 2008 | TV Receivers & DVRs
TV Receivers & DVRs Logo
591 people viewed this question
Top Lite On TV Receivers & DVRs Experts
Jaime Hernandez
Are you a Lite On TV Receiver and DVR Expert? Answer questions, earn points and help others
