Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Dishwasher not draining
Water standing up in bottom of dishwasher after cleaning not draining water left standing after cleaning and drying cycle
  • 2 more comments
  • tamjohn1 Dec 28, 2007
    Yeh when the cycle is done it still has water in the bottom of it and it wont during the light wash cycle it won't eject water out for cleaning so what could be the problem but it works during other cycles.
  • Anonymous Jun 12, 2008
  • Anonymous Oct 22, 2008
    Water is still eft in bottom of DW after cycle ends. Is the pump gon eout or is the drain clogged. Everything else seems to be okay.
  • jimsmessages Jan 08, 2009
    Kenmore Ultrawash dishwater still isn't drain. Hose and connectors are clean from end to end. Is there an easy way to clear any debris from inside the tub to make sure the clog isn't from inside the tub?
    Problem Solver:
  • 17 Answers
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
Posted on Feb 16, 2009
I still have water in the bottom when the cycle is all finished
Posted on Nov 12, 2008
    Problem Solver:
  • 10 Answers
Your pump is stopped up
Posted on Dec 15, 2007
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
GE dishwasher PDWT480R10SS does not fully drain at end of cycle
you need to clean the outside edge of the disk at the bottom of washer and put high heat silicone around the outside edge and let it dry 24 hours before use, if it still doesn't drain all the way ,you will have to replace the disk. I have repaired many of these . good silicon should do it.
Sep 14, 2014 | GE Dishwashers
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
I have a brand new whirlpool DU1055XTV5 dishwasher, installed two days ago. After the cycle completes there is about 1/2" clean standing water left in the bottom. It is not just down in the well area,...
Ensure the outlet pipe is below the level of your floor and straight to a drain or plumbed into the waste pipe directly with no chance of syphoning from standing water in your drain/waste pipe.
Apr 04, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Doesn't drain after "normal cycle" is run
It does sound like you have a switch problem or like the knob is simply getting stuck. Try taking it off and cleaning it if possible. Most common hardware problems with draining you have water at the bottom and it will not drain no matter what untill you clean the drain hose or a valve. Good news is that it doesn't sound like an expensive fix. Good luck.
Jul 14, 2009 | Whirlpool 24 in. DP840SWP Free-standing...
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
878 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
