please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation,
the drain pump might be defective or might have some debris in it. This
is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
and the noise is a continuous drone similar in speed to the circulation
pump sound, it's likely that the circulation pump motor bearings have
failed. Once this happens the circulation pump will have to be replaced,
the bearings are not repairable.
Drain Impeller
the drain impeller might be broken, or there might be debris in the
pump. Generally, to gain access to the pump the top of the pump housing
will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings,
drain impeller or wash impeller might have worn out. All three of these
components are part of the pump and motor assembly. It may be possible
to replace one of the impellers, but the motor bearings cannot be
repaired. In that case the pump and motor assembly will need to be
replaced.
Wash Impeller
The wash impeller is a small, plastic blade.
The motor spins the impeller forcing water through the spray arms to
clean the dishes. If one or more blades has broken off of the impeller
the dishwasher is loud. The impeller can also scrape against the pump
housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
and the noise is a continuous drone similar in speed to the motor sound,
it's likely that the circulation and drain pump motor bearings have
failed. Once this happens the motor will have to be replaced, the
Water Inlet Valve
The water inlet valve is an electrically
controlled water valve. When it is new, the water inlet valve is very
quiet. Over time, the diaphragm inside the valve deteriorates and
deforms. This deformation interacts with the water rushing in and can
cause a loud vibration, buzzing, squealing or other noises. If the
dishwasher is loud during the filling cycle, replacing the water inlet
valve may solve the problem.
Ch hardware store and Lowes are dealer for Agrifab. I suggest starting there.
