Question about Denon AVR-884 6.1 Channels Receiver
Problem with Denon AVR-884 - shuts itself off with higher volume
My Denon AVR-884 is working only with very low volume, with higher volume it's shutting itself off. I check the speaker connections and they are connected properly (in phase). I have 5 speaker connections for 2 front, 2 back and center + active subwoofer.
I hooked up cable box via component and optical, DVD via component and digital coax. (out via component to my projector). Additionally I have hooked up CD player via RCA cable and VCR/DVD combo via component cable. (out via RCA video to the projector).
Can you help me figure out why the receiver is shutting itself off at higher volume? It was plugged in like that for years and now something happened. Thanks. Konrad
Soulvisitor
  • 1113 Answers
SOURCE: Problem with video signals through AVR-4800
Pic of product.
Owners manual
I'll be back after I study it, if problem persisit
Check monitor 1 settings in the on screen display on tv for me
Cheers
S.
Posted on Jan 14, 2008
bestdarngood
  • 3037 Answers
SOURCE: Denon AVR-1906
It sounds like the receiver has a loose internal or unprotected part causing interference most likely a defect, I would take it back and get a different one if you can and then let us know if the same thing happens. If it does then you have other problems but I think that you just have a defective unit. Let me know how this goes and if you need further help, just ask
good luck
Posted on Jun 04, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 163 Answers
SOURCE: Have put an optical cable from optical digital out
You need to do digital input assignment. Go to SETUP, DIGITAL INPUT ASSIGNMENT, set OPTICAL 1 for your input (DVD).
Posted on Apr 09, 2009
SOURCE: No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Posted on Apr 12, 2009
How do i hook up auxillary chord to a denon avr-884
There are several "line" inputs that should work.you will need an adapter to go from 3/5mm [1/8" phone] to RCA Stereo. This can be a cable with Male 3.5 mm stereo on one end and two RCA male on the other, or a 3.5 M-M cable plus a 3.5 female to RCA male adapter. or a stereo M-M RCA cable with RCA F to 3.5 Male...
If you have easy access to the back panel, plug into and use the CD/Tape [IN]. Or you can simply plug the RCAs into the front L and R audio and use that input sans video.
Jan 03, 2015 | Denon Audio Players & Recorders
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
Volume coming from tv is so low
you have to goto setting and set the speaker to tv if you have a newer tv
Mar 28, 2014 | Denon AVR-1513
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
Denon avr-1708 receiver heats up and shuts off when volume turned up passed 0.0db or +0.5db. i am running 6-8" sonance 6oh speakers and have a fan blowing across the top of the receiver. it only...
Are you trying to kill it? A device has only so many emergency shut-offs it can withstand.
How are the spaces around the top, underside and back for ventilation?
0 dB isn't normally 'normal' volume.
I wonder if the fan is a self-defeating work-around because the noise might make you want to crank it up so higher so you can hear it.
Apple TV? Is it a dynamically-compressed audio signal? That would raise the average volume.
Feb 21, 2011 | Denon AVR-1708 Receiver
Denon avr 1907 low volume on all chans.with the
Maybe the audio amplifier IC are fried and need to be replaced
Apr 22, 2010 | Denon AVR-1907 Receiver
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
My AVR 2803 shuts down when volume is at medium or above.
too big a speaker load,unit sensors shut unit down when speaker impedance gets too low . and draws too much current at hi volume.A bad woofer or tweeter voice coil burned by sudden excess volume can cause this,also partially shorted speaker wires.
Jan 03, 2009 | Denon AVR-2803 Receiver
Denon AVR-884 6.1 Channels Receiver Logo
61 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
