Question about LG DR-4912 DVD Recorder
LG 4912 using with a new digital TV
I have just purchased a new digital TV (also containing an analogue tuner) I am trying to connect to my DVD recorder, whilst I can locate the analgue channels I cannot access the digitial channel so am unable to record digital? Any advice gratefully received.
Thanks
  • Anonymous Dec 30, 2007
    analogue channels are tuned in but one station is digital. Cannot tune it in
    Master:
  • 619 Answers
In order to solve the complect of channel/ choose one / if tv is digital in line w/dvd is digital.
If your your recorder is analogue choose use analogue channel.
Posted on Jan 03, 2008
Where can I buy a digital tv tuner to replace the analog tuner in a DVDRHD04
Generally recording machines fitted with an analogue tuner can only continue to be used to record digital tv by using a digital set-top box.
It would not be practical or economic to remove the internal analogue tuner and replace it with a digital tuner unless the person is a highly skilled and experienced repairer.
Digital set-top boxes are available from all sorts of outlets at all sorts of prices. Many surplus boxes can be found at boot sales, garage or yard sales or charity shops at very low prices.
Most boxes have the minimum of connections and often offer only a scart output but some of the older, more expensive and usually better quality boxes also contained a UHF tuner in a similar way to the old vhs recorders so even older tv sets could be used with digital even though no scart input was fitted.
Dec 03, 2015 | iLO DVDRH04 DVD Recorder
Lg 26lh2000 wont auto retune, help please.
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
I am unable to record digital tv channels on my LG RC389H dvd recorder. I have a new tv with a digital tuner and have hooked them up but unable to view any digital tv on my LG player only the old analogue...
The RC389H is only deigned to receive standard TV signals, not digital. If you are routing through a straight cable line you usually can't access anything above 100 if you don't have a digital tuner. Try using a cable/satellite box if you haven't already, this bypasses the requirement for a digital tuner because the cable/satellite box has one of it's own.
Aug 27, 2011 | LG Televison & Video
My samsung dvd hr753 will not tune to stations? Our region recently switched to digital so we no longer have analogue signals. Could this be the problem?
Yes this is your problem that you no longer receive an Analogue Signal.
This unit doesn't contain a Digital Freeview Tuner so you will need to purchase some sort of External Digital Freeview Box to connect to this unit to enable you to continue recording on it.
Jul 11, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
LG RH277H aerial reception
relocate antenna or buy hdtv antenna. use hdmi cable for the dvd rec to tv. adjust dvd rec input source to hdmi.
Jun 12, 2017 | Televison & Video
Snowy reception on TV with LG DVB418
have you got both cables going into your video ?? if not you need a video splitter to input both the digital and analogue aerials then have a coaxial cable going to the tv
Mar 08, 2009 | LG DVB418 DVD Player
LG DR-4912 DVD Recorder Logo
200 people viewed this question
Steve Allison
Steve Allison
