Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Faulty LCD monitor display
Monitor displays picture but has distorted (stepped) blocks of colour in columns in TV mode. On screen display graphics are OK.
Haven't tried SCART or PC input.
Please advise
    Problem Solver:
  • 11 Answers
Could be that you are not recieving a strong enough signal from your cabel company, give them a call and they can come out and check, try a DVD or something else that will tell you for sure
Posted on Jan 21, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Fading colour
- Flickering screen
- Dim screen
- Slow start
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Coloured lines across the computer
Hook a spare monitor to the video output, if picture okay the LCD panel display will need to be replaced, go to www.ebay.com type make and model of laptop, refine search to screen. But if both show the same symptom it is the video graphics card.
Jun 03, 2012 | IBM ThinkPad T40p 2373 Notebook
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
Coloured squares appear on screen
Seems to me that the LCD cables are not properly atached.
Double check all the LCD connections.
Your problem will be solved.
Jul 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
Horrible fuzzy display on my external lcd tv monitor - sadness
You need to change the resolution and colour quality under graphics properties on second monito. Put the settings back under the advanced tab, your just pushing new monitor over its limits. You dont need to have the same resolution set as your PC screen. Hope this works for you.
Mar 18, 2010 | ASUS Eee PC 1000HE Netbook
Input not Supported
The signal being sent is outside of the rated limits of the monitor (vertical or horizontal synch rates). Boot up in safe mode (by hitting F8 during the initial startup of the computer, before the windows logo screen comes up). Select Safe Mode. If you get a display in this mode, then you know your graphics card is sending a signal outside of the monitors limits, if not, then the monitor itself is probably bad. NOTE: The following steps are for Windows XP only... if you have a different OS, please reply and I'll research the steps for you.
If it is your graphics card, while in safe mode, right click on My Computer and choose Properties. Click on the Hardware tab. Click on Device Manager and double click the Display Adapter entry. Right click on your graphics card and click uninstall. This will force the computer to reinstall the graphics drivers at bootup and, hopefully, reset the adapters output mode. Reboot the system and once in, set your display settings to the best for your monitor (Windows XP should pick the best setting if the monitor is plug and play).
Feb 19, 2010 | Acer 22" X223w LCD Monitor
Distorted display/aspect HP w1907
This is a common problem with wide screen format.
The way I overcome this distortion is to open a drawing program and draw a circle, some programs require you to hold down the shift key to produce a perfect circle.
I then go to the Display Settings and adjust the screen resolution to get the best display that fills the screen and that gives me the perfect circle.
If this does not work you may need to download the latest video driver for your graphics card and then adjust the screen resolution..
Aug 22, 2009 | HP w1907 LCD Monitor
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
97 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
