Question about HP LaserJet 2605dn Printer
HP 2605dn stopped working red light on.
I tried printing a PDF file with a lot of color and detail and got an error message on the computer and the printer red and green light is on. The status screen on the printer just shows "Hewlett-Packard" I've unplugged the network cable and power and turned it on and off with no results. Also, there is no blinking light where the network cable plugs in.
  • Anonymous Jun 05, 2008
    same thing, except it never did work, right out of the box
2 Suggested Answers
  • 2069 Answers
SOURCE: We have four computers, 3 Macs and a PC networked
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Posted on Nov 23, 2010
�Hp laserjet 1600 red color print out very low (new cartridge)
- the problem might be with the laser/scanner assembly of the printer, it is probably dirty
- http://www.formyfriendswithmacs.com/images/don-thompson-2605dn.pdf
- refer to an HP Authorized Service Provider to solve the problem
Aug 01, 2010 | HP LaserJet 1600 Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
When i send a file to print from my mac (OSX 10.4.11) i get the error message in the printer box ''Printer not responding''I am using the HP 2500 Color LaserJet printer. It was working fine and just...
Connect the computer via fire wire to another working one.. and remove the two sleep files. Start your MBP holding down the T key The issue is a corrupt sleep file. once deleted your computer will work perfectly
Nov 11, 2009 | HP Color LaserJet 2500L Laser Printer, up...
My HP 2605DN when it prints the red is missing from the pictures.
My HP2605dn does this about every 6 months. I am getting fast at fixing it. The laser mirror for the red ink is dirty and needs to be cleaned. I use a Q-tip, rubbing alchohol, and air. The problem is that the mirror is way, way, way inside and you need to remove about 40 screws. The first time it took me 4 hours. Today it took me 20 minutes!. I put the instructions on my web site.
http://www.dbconstruction.com/hp2600repair.pdf
Jan 18, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Prints a pdf in all red colors.
Try this open the pdf in acrobat reader: Go to File > print > advanced > choose print as an image.
Nov 12, 2008 | HP LaserJet 2840 Printer
HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
May 15, 2008 | HP Color LaserJet 2600n Printer
2605dn prints red background randomly
n the Windows environment, the Automatic and Manual color options are on the Color tab in the printer driver. choose manual and click on grayscale
Jan 09, 2008 | HP Color LaserJet 2600n Printer
Colors are uneven, too much green on the right side and too much red on the left
The internal optics are dirty. It's a known problem that HP's been ignoring.  More info is here:  http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1202453734788+28353475&threadId=1073731
Detailed instructions are on this page - look for Don Thompson's posting at Sep 15, 2007 23:38:51 GMT and click the papercliip to see the procedure. It's not for the faint of heart.
Dec 12, 2007 | HP Color LaserJet 2600n Printer
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
