HP Color LaserJet 2600n Printer
Problem for HP Color LaserJet 2600n Printer
Printer problem
By Alex_Scr_23 on Dec 14, 2007
The error that i recieved is "floating point overflow" on a: Hp color laserjet 2006n (the same problem is the same for the other PC form the network) thank you for your time and i'll wait your answer.
Comments:
Dec 14, 2007
- Thank you for your answer. I'm starting to believe that is more a network problem that a printer one. I'v searched on the net and found out more about that kind of error but, not a practical support.
Solution #1
posted on Dec 14, 2007
Somewhat Helpful)
cheapread
Rank: Apprentice
Rating: 70%, 1 votes
Hi, I don't think you should be looking at the li'l ol printer to blame this on - they are dumb machines and the nearest u would get to blaming the ptr. would be a complex archtectural drawing that the ptr. wouldnt have enough memory for - but I dont think that is the case here and that wouldnt be the error that the printer would show up.
Look at your PCs and app .
At worst case try another prt. driver not PCL6 but as I say try looking elsewhere than the ptr.
good luck
Was this helpful?
Yes
No
Solution #2
posted on Jan 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It appears this is something to do with the way the network printer driver works, and only appears to be a problem when using a networked\shared printer. The problem occurs when the Windows API .EndDoc procedure is called, apparantly if you configure the compiler to ignore floating point overflows this seems to work OK, but thats sounds like a horrible solution.
I am unsure of the context of your problem but judging by the website you're probably printing, rather than writing code, so my advice would be to contact the vendor to see if they have updated software. We had this problem with our software, and had to change it as above.
I'm sorry thats not the best of help, the only other work around is to connect to the printer locally\directly.
Ross
Popular Solutions for HP Color LaserJet 2600n
Questions and Unsolved Problems for HP Color LaserJet 2600n
Do you recommend HP Color LaserJet 2600n Printer?
Answer
Answer
The network connection no longer works on my printer, this is the second HP 2600 this has happened... (More)
Answer
i have a paper jam and we cant find it. is there any way to take of the top
Answer
My printer ghosts 1.5 inches in from the right margins- sometimes it works itself out after 10 or... (More)
Answer
cyan and yellow colors look faded I have near new HP toners installed I have cleaned belt in front... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
