Question about iiyama Vision Master Pro 510 22" CRT Monitor
Iiama vision master pro 511 MA201D - horizontal distortion adiustment
Hi! I need your advice. How can I enter to factory/service menu in Iiama vision master pro 511 MA201D?
FACTORY MODE:
Turn ON and OFF the Power Switch while pressing the MENU Button. Turn ON the Power Switch again while
pressing the – Button and you are in the Factory Mode. The following menu appears on the screen when you
press the MENU Button. Turn OFF the Power Switch to exit
Posted on Jul 03, 2008
Securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 5000 Cellular Phone
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Windows 7 doesn't recognize my iiyama Vision Master Pro 450 Monitor, what to do?
    My Iiyama Vision Master Pro 450 works with Windows 7 when connected with a VGA video cable that has 5 BNC RGB connectors that attach to the back of the Iiyama monitor. No driver install was needed; Windows 7 shows my Iiyama monitor as a "Generic Non-PnP Monitor" with 1024x768 resolution.
    Jan 13, 2011 | iiyama Vision Master Pro 450 Monitor
    The extreme left 1/3 side of our 2007 46" TV is distorted (almost like double vision)and several lines running horizontally. Is there an adjustment we can make?
    CONVERGENCE FAILURE. YOU CAN CHECK THE CONVERGENCE ADJUSTMENT IN THE MENU LOCATED IN THE PICTURE SUBMENU. IF IT WONT ALIGN THEN YOU SHOULD CALL A SERVICEMAN
    Dec 17, 2010 | Toshiba Televison & Video
    19" Iiyama HM903DT A Vision Master Pro 454 not detected
    Try downloading and installing drivers.
    I found some here:
    http://www.howtodrivers.com/model38655.html
    Nov 10, 2009 | iiyama Vision Master Pro 454 19" CRT...
    Connection
    Hi...there,
    Try Red, Green, Blue that is a sequence. settings all to 100% Have a nice day!
    Feb 02, 2009 | iiyama Vision Master 404 Monitor
    Monitor problem
    Un Plug the monitor and let it sit for a few hours.
    Jun 29, 2008 | Gateway FPD2275W LCD Monitor
    Red convergerce not working
    there is an auto restore option on the onscreen menu its sort of hidden you need to scroll down all the way to the bottom past the multipoint options give that a try
    Nov 09, 2007 | Philips 51PW9363 51" Rear Projection...
    Compressed Screen
    if you get a video camera & wave it from left to right while pointing it at the screen you'll just see the image in the flicker
    Aug 24, 2006 | iiyama Vision Master Pro 510 22" CRT...
    iiyama Vision Master Pro 510 22" CRT Monitor Logo
    524 people viewed this question
    Top iiyama Computers & Internet Experts
    William Miller
    William Miller
    RS Technology...
    RS Technology...
    Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
