Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Test display The display lights on my machine say test whenever I start a cycle. I have lft the test cycle do its thing and try again and test continues to appear. On the test cycle it dosn't take on water or powder just seens to go around in differnt directions. i hve taken both hot/cold pipes off and tested them,als the same for th outflow pipe. I have read my manual and can't find a solution. please help Mr Eccott
  • Anonymous Sep 20, 2008
    same problem
  • 75 Answers
Hi there let your machine do the compleat test cycle again then when it gets to the end press and hold the start/cancel button and the on/off button at the same time for at least ten seconds.
hope this is of some help
Posted on Dec 14, 2007
Hi my WD640 is merrily testing away and I have repeated the above solution numerous times to no avail.  Turned off and on many times and still no joy.  Help
Posted on Dec 18, 2007
Whirlpool washer rinses too many times!
The control board (machine electronic control) is faulty
Feb 06, 2016 | Whirlpool Washing Machines
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
First time it happen I notice that it started before it should with the timer, so started it without timer and it worked. Now its not going though circle again. Changing the program, and trying again,...
1) you must test the timer is stuck with the contacts, you can try to clean it, tight loose wires, test wires open or break. Or doesnot replace complete TIMER. The timer contacts if you see the diagram is determinant control all operation machine of the diswasher. God bless you
God bless you
Jul 10, 2012 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Jul 15, 2009 | Washing Machines
Hotpoint wf840 displays "test"
Try This - It works for the Washer Dryers so it May work on your Washer.
  1. Press the Start/Cancel button until all the console Led's Illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Hope this Helps.
Mar 12, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Display lights
make sure there water going to machine, remove fill hose to see check inlet filters.good luck eire
Dec 07, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message "test"
yhe washing machine has been put into test mode to get out of this mode you must press and hold down the On/Off and Start/Cancel buttons until "d off" is displayed that will get you out of the test mode
Jun 24, 2007 | Hotpoint Aquarius WD640 Front Load...
Trouble starting Cycles
Jonsey, sounds like you have a keypad issue here. Do this test: press the following keys in this order soak-cycle signal-soak-cycle signal. If done right the display should show dt. Now press start, all the led's will light up. Now test them by pressing each one, you should hear a beep for each one. If some of them are not responding, check the P-11 and P-12 harness on the control board. You can also put this machine in the automatic test mode by pressing the keypads in this order; soak-soil level-soak-soil level. The display will start counting down from 99 to 0 testing different aspects of the machine. Any errors will be shown in the display. Catriver..post back.
Nov 13, 2006 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
120 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
